| skaufmann |
Jul 18 2012, 12:36 PM
Blissfully Ignorant ![]() ![]() Group: Members Posts: 103 Joined: 26-May 11 From: San Diego - College Area Member No.: 13,123 Region Association: Southern California |
I only have the original Valet key that turns the ignition. I have a 2nd key (Master) that opens the passenger door (and nothing else) and a 3rd key (Valet) that open the driver door (and nothing else).
From what I can gather, the only difference between the master key and the valet key is the channeling down the side of the key, not the notch/tooth profile. If I'm correct, can I make a copy of the original Valet key to a new Master key? My thought is it's easier to rekey the door locks and I suspect the new Master will then work the trunk and glove box since those were not likely replaced like the door locks were. |
| doug_b_928 |
Feb 20 2017, 06:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 718 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
Good to know that might be an option.
skaufmann Can I make a Master Key from Valet Key? Jul 18 2012, 12:36 PM
r_towle You should be able to use the valet key to make a ... Jul 18 2012, 12:46 PM
skaufmann
You should be able to use the valet key to make a... Jul 18 2012, 12:51 PM
r_towle If I recall correctly, the glove box and front tru... Jul 18 2012, 01:02 PM
markb GPR sells originals & repros of the keys. Take... Jul 18 2012, 01:10 PM
skaufmann Awesome help guys!
Is there a source for wafe... Jul 18 2012, 02:39 PM
markb
Awesome help guys!
Is there a source for waf... Jul 18 2012, 02:48 PM
barefoot
Awesome help guys!
Is there a source for wa... Jun 27 2013, 08:02 AM
doug_b_928 My car only came with a valet key. Reading on the... Feb 18 2017, 08:19 PM
Racer Chris
My car only came with a valet key. Reading on th... Feb 20 2017, 02:05 PM
doug_b_928 Bump in the hopes that someone with a better under... Feb 19 2017, 08:09 PM
914 RZ-1 When I got my car I had 3 keys to various combinat... Feb 19 2017, 09:58 PM
slivel I recently had an extra key made for my 1975 914 a... Feb 20 2017, 11:15 AM
doug_b_928 Hmmm...so maybe I can try it out with a blank from... Feb 20 2017, 11:53 AM
The Cabinetmaker The cut is the same on both master and valet. Yes,... Feb 20 2017, 01:17 PM
doug_b_928 The nuance that was not obvious to me is whether t... Feb 20 2017, 01:26 PM
doug_b_928 Very nice explanation. Thank you! Feb 20 2017, 02:46 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th November 2025 - 06:41 PM |
