> Can I make a Master Key from Valet Key?
skaufmann
post Jul 18 2012, 12:36 PM
Blissfully Ignorant
I only have the original Valet key that turns the ignition. I have a 2nd key (Master) that opens the passenger door (and nothing else) and a 3rd key (Valet) that open the driver door (and nothing else).
From what I can gather, the only difference between the master key and the valet key is the channeling down the side of the key, not the notch/tooth profile. If I'm correct, can I make a copy of the original Valet key to a new Master key?
My thought is it's easier to rekey the door locks and I suspect the new Master will then work the trunk and glove box since those were not likely replaced like the door locks were.
slivel
post Feb 20 2017, 11:15 AM
Old car....... older driver
I recently had an extra key made for my 1975 914 and the locksmith didn't have any blanks for Porsche but found that a blank for older VW is the same.
skaufmann   Can I make a Master Key from Valet Key?   Jul 18 2012, 12:36 PM
r_towle   You should be able to use the valet key to make a ...   Jul 18 2012, 12:46 PM
skaufmann   You should be able to use the valet key to make a...   Jul 18 2012, 12:51 PM
r_towle   If I recall correctly, the glove box and front tru...   Jul 18 2012, 01:02 PM
markb   GPR sells originals & repros of the keys. Take...   Jul 18 2012, 01:10 PM
skaufmann   Awesome help guys! Is there a source for wafe...   Jul 18 2012, 02:39 PM
markb   Awesome help guys! Is there a source for waf...   Jul 18 2012, 02:48 PM
barefoot   Awesome help guys! Is there a source for wa...   Jun 27 2013, 08:02 AM
doug_b_928   My car only came with a valet key. Reading on the...   Feb 18 2017, 08:19 PM
Racer Chris   My car only came with a valet key. Reading on th...   Feb 20 2017, 02:05 PM
doug_b_928   Bump in the hopes that someone with a better under...   Feb 19 2017, 08:09 PM
914 RZ-1   When I got my car I had 3 keys to various combinat...   Feb 19 2017, 09:58 PM
doug_b_928   Good to know that might be an option.   Feb 20 2017, 06:24 AM
slivel   I recently had an extra key made for my 1975 914 a...   Feb 20 2017, 11:15 AM
doug_b_928   Hmmm...so maybe I can try it out with a blank from...   Feb 20 2017, 11:53 AM
The Cabinetmaker   The cut is the same on both master and valet. Yes,...   Feb 20 2017, 01:17 PM
doug_b_928   The nuance that was not obvious to me is whether t...   Feb 20 2017, 01:26 PM
doug_b_928   Very nice explanation. Thank you!   Feb 20 2017, 02:46 PM
- Lo-Fi Version Time is now: 19th November 2025 - 06:44 PM
