AAV testing, Manual and electric |
malcolm2 |
Feb 20 2017, 05:59 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Ok. I have had the AAV off for a couple weeks now. I figured it was time to re-install. Wanted to test it first.
I put it in the freezer. The valve was open before and after. I got the wife hair dryer out and got it hot enough to NOT hold on to. But the valve stayed open. I got my drill battery out and jumped it to the connector. Very quickly the valve closed. I decided to blow threw it. Air did not move quickly thru it, but i could hear the hissing as it came out. So the question is: is the AAV supposed to close up tight? |
malcolm2 |
Feb 21 2017, 09:25 PM
I also checked Pin 88d of the dual relay to one pin of that connector and it showed continuity.
The other pin on the AAV connector showed continuity to ECU pin 34. |
Lo-Fi Version | Time is now: 29th May 2024 - 02:45 AM |
