| kupcar |
Jan 24 2017, 05:46 PM
Member ![]() ![]() Group: Members Posts: 95 Joined: 14-February 13 From: Chicago Member No.: 15,528 Region Association: None |
Hi Guys, It's time to do some routine off season maintenance on the 914. The car has a 2.2s spec motor. My question is, how do -6 owners adjust the ignition timing prior to a valve adjustment? It looks damn near impossible to get a timing light reading. I know cutting into the firewall is an option for ease of access but I'm not willing to get the cutoff wheel out yet. Does everyone drop the motor and tune at a shop that has a running motor stand? I'd just like to double check the ignition before setting the valves. Thanks in advance.
| Mark Henry |
Feb 22 2017, 05:16 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
There's a cool tool made by a pelican member that replaces using feeler gauges.
A bit spendy though at $85. http://www.pelicanparts.com/catalog/SuperC...L_pg2.htm#item6 |
kupcar 914-6 Valve Adjustment Advice Jan 24 2017, 05:46 PM
jcd914 Smoke and Mirrors!
Well actually you don... Jan 24 2017, 05:50 PM
toolguy That is why real six's have the timing marks o... Jan 24 2017, 05:59 PM
mountainroads
That is why real six's have the timing marks ... Jan 25 2017, 09:32 AM
6freak
That is why real six's have the timing marks ... Jan 25 2017, 12:38 PM
fixer34 Your 'fun' has only begun. Wait until you ... Jan 24 2017, 06:42 PM
kupcar I actually thought about the mirror. Then I envisi... Jan 24 2017, 07:07 PM
fixer34
I actually thought about the mirror. Then I envis... Jan 26 2017, 05:19 PM
GeorgeRud You could always put paint marks on TDC and at the... Jan 24 2017, 07:37 PM
mskala If you really don't have any timing marks on t... Jan 24 2017, 08:06 PM
kupcar George, Thanks for the picture. I didn't even ... Jan 24 2017, 08:32 PM
maxwelj
Mark, I do have access to a lift. I'm going ... Jan 25 2017, 11:32 AM
porschetub never seen the point in these exhaust valve covers... Jan 24 2017, 08:41 PM
'73-914kid I exclusively use the back side method as describe... Jan 24 2017, 09:37 PM
mskala
... Oh, and you can replace the upper row of stud... Jan 25 2017, 08:32 AM
'73-914kid
... Oh, and you can replace the upper row of stu... Jan 25 2017, 08:56 AM
6freak [quote
Just use good judgement when tightening do... Jan 25 2017, 12:52 PM
Peashooter That's a great idea on replacing the top row o... Jan 25 2017, 08:21 AM
kupcar Great tips! I can't wait to dive into this... Jan 25 2017, 09:07 AM
rudedude Also the 6 cylinder valve spec is 0.01mm or .004... Jan 25 2017, 12:27 PM
Perry Kiehl Taking off the exhaust adds time and materials, bu... Jan 27 2017, 08:11 AM
db9146 Ethan,
Question regarding your suggestion to repl... Feb 1 2017, 09:29 PM
'73-914kid That's a great question. I actually don't ... Feb 1 2017, 10:08 PM
db9146 That would be fastastic!!!!
I rea... Feb 1 2017, 10:46 PM
forrestkhaag So if you want to "see" your pulley and ... Feb 1 2017, 10:57 PM
forrestkhaag I am taking PK's advice on milling depth of 5/... Feb 22 2017, 03:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:18 AM |
