| GeorgeRud |
Feb 22 2017, 03:33 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
As I have no bodywork experience, I wonder if it's standard to completely cover the body with filler, then sand it down (as seen on many of the Velocity Channel restoration shows) before applying primer and color coats? Obviously this amount of hand crafting is not done during initial manufacturing, but is there an advantage to this? Seems a high build sealing primer would make this unnecessary.
| McMark |
Feb 23 2017, 06:44 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
It's the same as every other aspect of a restoration, you get what you pay for. It's W_A_Y easier to put a thin skim coat over the whole car and then just block it smooth, instead of applying filler just to the 'dents'. Most of the time on an older car you don't realize that the body is full of waves and bumps. And that doesn't even get into the mismatch of panels. Sometimes the only way to make a car with a replaced fender line up is to build up a section with bondo. If you use a skim coat over the whole car you skip the process of deciding where to put filler, you skip the 'oops I missed a spot'. You get it all in one shot and can move on quickly.
1. Entire Skim Coat = cheap, and still can look amazing or crap depending on the body guy. 2. Minimize Filler = quite a bit more expensive, and still can look amazing or crap depending on the body guy. 3. No Filler = insanely expensive, and still can look amazing or crap depending on the body guy So before ya'll go and condemn bondo/filler, think about how much you would pay for paint/metalwork. If you think $5000 is too much for a paint job, then you can't afford option 2 & 3. Bondo/Filler doesn't make or break a paint job, it's exclusively your budget and the skills of the body guy. |
GeorgeRud Body Filler Feb 22 2017, 03:33 PM
john77
As I have no bodywork experience, I wonder if it... Feb 22 2017, 04:03 PM
As I have no bodywork experience, I wonder if it... Feb 22 2017, 04:38 PM
Unobtanium-inc Is it a "correct" way to restore, no, bu... Feb 22 2017, 05:21 PM
Olympic 1.7
Is it a "correct" way to restore, no, b... Feb 22 2017, 08:08 PM
Cairo94507 I think the goal would be no thicker than a credit... Feb 22 2017, 06:03 PM
bretth Say no to bondo. My car was repainted by a previou... Feb 22 2017, 07:01 PM
Unobtanium-inc Bondo is also handy for fixing holes in the course... Feb 22 2017, 07:37 PM
cary Less is more.
Hammer & dolly. Stud gun and sl... Feb 22 2017, 07:59 PM
Dave_Darling Very very basic:
In theory, a shop should work on... Feb 22 2017, 11:17 PM
porschetub I see the use of high build primer in the USA lots... Feb 22 2017, 11:54 PM
Darren C Bondo thats Slick...rhymes with dick Feb 23 2017, 06:10 AM
Mark Henry This would be my basic method, but I haven't p... Feb 23 2017, 07:44 AM
This would be my basic method, but I haven't ... Feb 23 2017, 08:12 AM
Mark Henry
I'm pretty sure the high build primer we use ... Feb 23 2017, 10:22 AM
veekry9 http://www.westsystem.com/ss/filler-selection-guid... Feb 23 2017, 08:14 AM
Unobtanium-inc Here's the question every man has to ask himse... Feb 23 2017, 08:58 AM
Andyrew The only thing that I have ever covered with fille... Feb 23 2017, 09:33 AM
rick 918-S Only use what you need. Here's a link that sho... Feb 24 2017, 02:34 PM
914forme I follow along with MP&C as he is a great meta... Feb 25 2017, 09:33 AM
doug_b_928 ^^^^Interesting video. I wonder if the same adhes... Feb 25 2017, 11:46 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:14 PM |
