Got 16" Fuchs in 6 and 7s, will they fit? |
RickS |
Feb 20 2017, 09:47 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
From my 82 SC I have a set of wheels and want to know if they would work on a teener with slightly flared rear fenders without using massive negative camber. The 914 is lowered and currently is on 15s, 6 and 7s.
Most importantly, what size tires? Would like to mount BFG Comp T/As Much grass |
DRPHIL914 |
Feb 23 2017, 07:06 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I'm going to say yes and no, not necessarily!- the 16x7" fuchs rubbed on mine and caused blistering of the paint on the fender!! - depends on the car-
I have 205/55-16 on front and rear- now, the fronts are 6^ and rears are 7" - but for our cars the proper diameter for the speedo is 205/50-16 since you already have 7" on rear of car with your 15" rims your 16" may fit , even after having fenders massaged to get the 7" to fit, its so tight, before I fix and repaint I will be going back to 6" rims, with spacer, - you see the 7" rims come out a whole inch further, the back space is same as the 6's, - if they were lets say a half inch less on outside and half more in, they would be perfect. but that is not the backset for the early staggerd 911 fuchs wheels. - but like I said, it varies from car to car, so good luck!!! Attached image(s) |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:37 AM |
