SOLD: Fuel Safe Sportsman 10 Gallon Fuel Cell $600, never used from tangerine racing |
FourBlades |
Feb 26 2017, 02:59 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
This is basically a brand new Fuel Safe Sportsman 10 gallon fuel cell I bought 5 years
ago which has been sitting in my living room. It has never had fuel in it. The foam in it is technically timed out, so you will have to replace it if you are in a series that cares about FIA legal fuel cells. I think contact with fuel is what degrades foam so this should be usable for a few years if you are not in a tightly controlled series. The cell is set up with two fuel pickups, one in each back corner. This was done to support a dual fuel pump operation where both pumps run all the time. You could run this with one pump and relocate the pickup or use the new Holley fuel mat. The cell has a return line fitting, provision for a fuel level sender, and a rollover valved vent fitting. This would make a great cell for autocross, track days, chump car, etc. for cars with four cylinder or smaller six cylinder motors. If you have a thirsty motor and are doing chump car or other endurance series then this is probably too small. This holds a similar amount of usable fuel to the Patrick motorsports cells that fits in the stock 914 fuel tank. The bladder and foam in the Patrick cell (which is very sweet setup) reduce the usable volume of the 15 gallon 914 tank to around 10 gallons. With this fuel cell in the front trunk it frees up the original gas tank area for your oil tank, fuel pumps, battery and other components. Mounting the fuel cell this way is not compatible with the 914 gt oil cooler shroud because the shroud intrudes too far into the front trunk. I could write a book about these issues after working on my IMSA car for so long... (IMG:style_emoticons/default/rolleyes.gif) I paid $1700 for this cell set up this way new. Asking $600 shipped to the CONUS. Shipping overseas would be pretty expensive but I will ship to anywhere else for actual shipping cost. Thanks...John |
mepstein |
Feb 26 2017, 07:15 PM
914-6 GT in waiting Group: Members Posts: 19,315 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
John - Sold & paid. Thank you, mark
Lo-Fi Version | Time is now: 9th June 2024 - 02:02 PM |
