76 vs 75 yom, Will they check in CA? |
jeffdon |
Mar 6 2017, 10:42 AM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
We all know that no 914's were built in 76. I have a 76 that clearly states on the door jam VIN sticker that was made in 09/75. So even though it has a 76 VIN, could one get the folks at the DMV to put it in as a 75? Or will they look up the VIN somehow? I do not think their computers even like our VINS that much.
Could one buffalo them into reging it as a 75??? |
Tom_T |
Mar 6 2017, 12:50 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
You might try it, but IIRC you'd need it running & roadworthy for the DMV safety inspection to get it back registered.
But if DMV in CA or other state still has it on the computer as a `76, then it may not work - may take some convincing. If Kent did it, then chat with him. Since the 76 MY 914s are a unique oddity - kinda the reverse of an early release of a model year, it would be great if California's DMV & CARB would accept the early YOM in 1975 as the definitive year relative to emissions requirements & the smog test waiver for `75 & earlier vehicles. Here's what the DMV website says: "Does my vehicle qualify for a smog exemption? Smog inspections are required unless your vehicle is: Gasoline powered 1975 year model or older Diesel powered 1997 year model and older or with a Gross Vehicle Weight rating (GVWR) of more than 14,000 lbs Electric Natural gas powered with a GVWR rating of more than 14,000 lbs. Motorcycle" > Source: https://www.dmv.ca.gov/portal/dmv/detail/vr/smogfaq But then Cal-BAr who runs the Smog Check program for CARB says this: "5. My 1976 model-year vehicle was built in 1975. Why isn't it exempt from Smog Check? The Smog Check exemption is based on the model-year of the vehicle, not the date of manufacture. Accordingly, a 1976 model-year vehicle is not exempt." > Source: https://www.bar.ca.gov/FormsPubs/Q&As_S....html#Question5 I can't find my link to the actual CA law wording, but you can search it on any CA State Law database, but IIRC it also says 76 MY - not YOM based, as above. Also, there was legislation in the CA State Assembly &/or State Senate which would move the pre-1976 Smog Test Requirement ahead by a few years (up to +/- 1985 IIRC), but I don't know it's current status. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Lo-Fi Version | Time is now: 8th June 2024 - 04:45 PM |
