> High idle 2.0 djet, Been working on it for a little
Brasil914
post Mar 7 2017, 08:02 AM
Hey all my name is John. I have been using 914 as a resource for a while but just registered (I have questions). So I have a 73 2.0 hand me down from dad. And I have idle issues. History: 86 dad snapped spark plug. Got what he could out of it and then tried to vacuum the head thru the spark hole. Was worried that not every thing was out so never started it again, and forgot to drain the tank. It sat in garage and storage until 2008 when he gave it to me. First thing I did was run a borescope in the cylinder , couldn't see jack. So dropped the motor pulled the head and the cylinder was clean as a whistle. Did some work over about three years sourcing parts and such. And got it to run in 2010. Then moved to SC. Got it here six months later and started on it some more. No I have had down time from work and have started tinkering again after 2 years. I have replaced all hoses,injectors and seals, yesterday I opened and freed up the aar. All this I and I have gotten the idle down from 4K to just under 2k. I can get it down to about 1100 but I have to remove the hose from the MPS? ( the Can on the right wall). The second I get the hose near or on the nipple the engine throttles up th 2 k. And runs smoother. At 1100 it sounds rich a lot of back firing. ( exhaust ignition). Any ideas gents?
BeatNavy
post Mar 7 2017, 08:22 AM
The two most likely causes of a high idle in D-Jet, when everything else is adjusted and working, are vacuum leak and advanced timing. With a car that's been sitting for a long time, however, you REALLY need to go over everything -- all the sensors, all the wiring, valves adjusted, timing, fuel pressure, all potential seals/hoses, etc. etc. D-Jet works well and is not too hard to troubleshoot - except when it's been neglected for a long period of time. Then it can be a lot of "fun" to track down issues.
I know you said you replaced hoses and seals, which is good, but start trying to identify which ones maybe you didn't replace. Nothing is more frustrating (and fruitless) than chasing a symptom randomly or one with multiple root causes. So do your best to eliminate the variables:
1. Confirm timing.
2. Check to make sure there really are no vacuum leaks.
3. Connect that MPS again - can't really run without that, things go super-rich -- make sure it's functional
4. Verify ALL the sensors and various D-Jet components are serviceable and functioning correctly.
and most of all:
5. Read this website: http://members.rennlist.com/pbanders/djetparts.htm. That will help put a lot of this together so you can understand how things work. Good troubleshooting info there.
And (IMG:style_emoticons/default/welcome.png)
Brasil914
post Mar 7 2017, 08:28 AM
QUOTE(BeatNavy @ Mar 7 2017, 09:22 AM) *
1. Confirm timing.
and most of all:
Yeah I'm really not wanting to drop the motor again but probably need to do it just to Make sure fine tooth comb it. Thanks beat navy. Hooah. Prior army myself.
Brasil914   High idle 2.0 djet   Mar 7 2017, 08:02 AM
Brasil914   Hey all my name is John. I have been using 914 as...   Mar 7 2017, 08:10 AM
BeatNavy   The two most likely causes of a high idle in D-Jet...   Mar 7 2017, 08:22 AM
Brasil914   The two most likely causes of a high idle in D-Je...   Mar 7 2017, 08:28 AM
BeatNavy   You don't need to drop the motor to do any of ...   Mar 7 2017, 08:32 AM
JawjaPorsche   Did you replace the manifold gaskets? Air intake ...   Mar 7 2017, 11:51 AM
Philip W.   Did you replace the manifold gaskets? Air intake...   Mar 7 2017, 01:15 PM
Philip W.   reading back thru it seems if you have evaluated a...   Mar 7 2017, 01:45 PM
Dave_Darling   Make sure that you don't have any hoses that g...   Mar 7 2017, 03:41 PM
cgnj   Unmetered air. Check for leaks at the phenolic gas...   Mar 7 2017, 03:57 PM
Rand   4k idle can only be a huge open hole below the but...   Mar 7 2017, 04:08 PM
Brasil914   4k idle can only be a huge open hole below the bu...   Mar 7 2017, 06:40 PM
BeatNavy   I think it WAS 4K before he started hunting down l...   Mar 7 2017, 05:03 PM
Rand   Do you know Gunn1? OU812? Your style is so similar...   Mar 7 2017, 06:42 PM
Brasil914   Do you know Gunn1? OU812? Your style is so simila...   Mar 7 2017, 06:56 PM
Brasil914   Do you know Gunn1? OU812? Your style is so simila...   Mar 7 2017, 06:58 PM
The Cabinetmaker   Do you know Gunn1? OU812? Your style is so simil...   Mar 8 2017, 09:20 AM
Brasil914   I have to keep hunting for a leak I capped the thr...   Mar 7 2017, 06:51 PM
Rand   So your car is running ok (aside from the fast idl...   Mar 7 2017, 07:43 PM
Brasil914   So your car is running ok (aside from the fast id...   Mar 7 2017, 10:22 PM
rhodyguy   Did you only replace the ONE injector seal or all ...   Mar 8 2017, 08:19 AM
Brasil914   Did you only replace the ONE injector seal or all...   Mar 9 2017, 09:28 AM
Brasil914   Do y'all recommend hose clamps on all vacuum h...   Mar 9 2017, 09:38 AM
BeatNavy   I don't. It's my understanding if you use...   Mar 9 2017, 12:22 PM
Brasil914   :headbang: so found that I had a poorly seated inj...   Mar 9 2017, 02:41 PM
Philip W.   :headbang: so found that I had a poorly seated in...   Mar 9 2017, 02:49 PM
Dave_Darling   I put my box of gloves over the throttle body and...   Mar 9 2017, 07:02 PM
Brasil914   I put my box of gloves over the throttle body an...   Mar 10 2017, 10:31 AM
Brasil914   I replaced the points yesterday and set the timing...   Mar 9 2017, 03:23 PM
Rand   Troll needs to die, not be fed. Does this really ...   Mar 9 2017, 05:51 PM
Dave_Darling   The only vacuum hose you need is the one from the ...   Mar 10 2017, 03:19 PM
Brasil914   DD I really appreciate your help. So what I did ...   Mar 10 2017, 06:35 PM
mgphoto   That is toast, soldering does not work. check wit...   Mar 10 2017, 07:01 PM
rjames   That is toast, soldering does not work. check wi...   Mar 30 2019, 10:58 PM
mgphoto   Did you try spraying starting fluid around all the...   Mar 10 2017, 07:08 PM
Brasil914   I have sprayed starting fluid and nothing. The sol...   Mar 10 2017, 07:35 PM
mgphoto   I have sprayed starting fluid and nothing. The so...   Mar 10 2017, 09:31 PM
Brasil914   I have sprayed starting fluid and nothing. The s...   Mar 11 2017, 06:04 PM
mgphoto   [quote name='mgphoto' post='2462758' date='Mar 10...   Mar 11 2017, 06:31 PM
Spoke   I have sprayed starting fluid and nothing. The so...   Mar 30 2019, 01:14 PM
Brasil914   It is all original parts. It has 26,000 original m...   Mar 11 2017, 06:00 PM
ctc911ctc   This is a great story without an ending - My 2.0 i...   Mar 30 2019, 12:12 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:34 PM
