| Brasil914 |
Mar 7 2017, 08:02 AM
Newbie ![]() Group: Members Posts: 26 Joined: 7-March 17 From: Charleston, SC Member No.: 20,905 Region Association: South East States |
Hey all my name is John. I have been using 914 as a resource for a while but just registered (I have questions). So I have a 73 2.0 hand me down from dad. And I have idle issues. History: 86 dad snapped spark plug. Got what he could out of it and then tried to vacuum the head thru the spark hole. Was worried that not every thing was out so never started it again, and forgot to drain the tank. It sat in garage and storage until 2008 when he gave it to me. First thing I did was run a borescope in the cylinder , couldn't see jack. So dropped the motor pulled the head and the cylinder was clean as a whistle. Did some work over about three years sourcing parts and such. And got it to run in 2010. Then moved to SC. Got it here six months later and started on it some more. No I have had down time from work and have started tinkering again after 2 years. I have replaced all hoses,injectors and seals, yesterday I opened and freed up the aar. All this I and I have gotten the idle down from 4K to just under 2k. I can get it down to about 1100 but I have to remove the hose from the MPS? ( the Can on the right wall). The second I get the hose near or on the nipple the engine throttles up th 2 k. And runs smoother. At 1100 it sounds rich a lot of back firing. ( exhaust ignition). Any ideas gents?
| Rand |
Mar 7 2017, 04:08 PM
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,414 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
4k idle can only be a huge open hole below the butterfly (throttle body). Only so many places it can be. Timing, valve adjust, etc are important, but no way causing that high of an idle. It's a massive air leak, bigger than leaky injector seals, phenolic blocks, etc. Something is open.
| Brasil914 |
Mar 7 2017, 06:40 PM
4k idle can only be a huge open hole below the butterfly (throttle body). Only so many places it can be. Timing, valve adjust, etc are important, but no way causing that high of an idle. It's a massive air leak, bigger than leaky injector seals, phenolic blocks, etc. Something is open. It was a missing injector seal dut that was fixed. Before the post. Thank you all for the help. DD your every where haha. And when I do get it fully on the road I'll come done to bluffton. So as an update I was working on timing today. New points set the gap but noticed the primary copper wire was broke free of the plate so I sandwiched it between plate and points. Probably needs replaced. Put a timing light on it and was still off a little. Is the green or black hose the advance? (Newbie question I know ). I did pull a vacuum on the Mps and it held 18-20 psi for 10 min. Aar has been opened and freed. Throttle body and cold start have been resealed wit liquid gasket. Because I could find any. Just to let y'all know this is a 73 wit 26k original miles on it so never rebuilt never pulled apart (till now). Other than the hisses and fuel pump , oil and filter, and front clip. Everything is original. Shoot the four rubber rings on it are 83' rounded edge radials. |
Brasil914 High idle 2.0 djet Mar 7 2017, 08:02 AM
Brasil914
Hey all my name is John. I have been using 914 as... Mar 7 2017, 08:10 AM
BeatNavy The two most likely causes of a high idle in D-Jet... Mar 7 2017, 08:22 AM
Brasil914
The two most likely causes of a high idle in D-Je... Mar 7 2017, 08:28 AM
BeatNavy You don't need to drop the motor to do any of ... Mar 7 2017, 08:32 AM
JawjaPorsche Did you replace the manifold gaskets? Air intake ... Mar 7 2017, 11:51 AM
Philip W.
Did you replace the manifold gaskets? Air intake... Mar 7 2017, 01:15 PM
Philip W. reading back thru it seems if you have evaluated a... Mar 7 2017, 01:45 PM
Dave_Darling Make sure that you don't have any hoses that g... Mar 7 2017, 03:41 PM
cgnj Unmetered air. Check for leaks at the phenolic gas... Mar 7 2017, 03:57 PM
BeatNavy I think it WAS 4K before he started hunting down l... Mar 7 2017, 05:03 PM
Rand Do you know Gunn1? OU812? Your style is so similar... Mar 7 2017, 06:42 PM
Brasil914
Do you know Gunn1? OU812? Your style is so simila... Mar 7 2017, 06:56 PM
Brasil914
Do you know Gunn1? OU812? Your style is so simila... Mar 7 2017, 06:58 PM
The Cabinetmaker
Do you know Gunn1? OU812? Your style is so simil... Mar 8 2017, 09:20 AM
Brasil914 I have to keep hunting for a leak I capped the thr... Mar 7 2017, 06:51 PM
Rand So your car is running ok (aside from the fast idl... Mar 7 2017, 07:43 PM
Brasil914
So your car is running ok (aside from the fast id... Mar 7 2017, 10:22 PM
rhodyguy Did you only replace the ONE injector seal or all ... Mar 8 2017, 08:19 AM
Brasil914
Did you only replace the ONE injector seal or all... Mar 9 2017, 09:28 AM
Brasil914 Do y'all recommend hose clamps on all vacuum h... Mar 9 2017, 09:38 AM
BeatNavy I don't. It's my understanding if you use... Mar 9 2017, 12:22 PM
Brasil914 :headbang: so found that I had a poorly seated inj... Mar 9 2017, 02:41 PM
Philip W.
:headbang: so found that I had a poorly seated in... Mar 9 2017, 02:49 PM
Dave_Darling I put my box of gloves over the throttle body and... Mar 9 2017, 07:02 PM
Brasil914
I put my box of gloves over the throttle body an... Mar 10 2017, 10:31 AM
Brasil914 I replaced the points yesterday and set the timing... Mar 9 2017, 03:23 PM
Rand Troll needs to die, not be fed.
Does this really ... Mar 9 2017, 05:51 PM
Dave_Darling The only vacuum hose you need is the one from the ... Mar 10 2017, 03:19 PM
Brasil914 DD I really appreciate your help. So what I did ... Mar 10 2017, 06:35 PM
mgphoto That is toast, soldering does not work. check wit... Mar 10 2017, 07:01 PM
rjames
That is toast, soldering does not work. check wi... Mar 30 2019, 10:58 PM
mgphoto Did you try spraying starting fluid around all the... Mar 10 2017, 07:08 PM
Brasil914 I have sprayed starting fluid and nothing. The sol... Mar 10 2017, 07:35 PM
mgphoto
I have sprayed starting fluid and nothing. The so... Mar 10 2017, 09:31 PM
Brasil914
I have sprayed starting fluid and nothing. The s... Mar 11 2017, 06:04 PM
mgphoto
[quote name='mgphoto' post='2462758' date='Mar 10... Mar 11 2017, 06:31 PM
Spoke
I have sprayed starting fluid and nothing. The so... Mar 30 2019, 01:14 PM
Brasil914 It is all original parts. It has 26,000 original m... Mar 11 2017, 06:00 PM
ctc911ctc This is a great story without an ending - My 2.0 i... Mar 30 2019, 12:12 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:34 PM |
