> Cam Gear Replacement, What bolts to use?
Allan
post Oct 25 2004, 12:25 PM
Teenerless Weenie
Got a replacement cam gear over the weekend thanks to Slits (IMG:style_emoticons/default/smilie_pokal.gif) Anyone recommend the right bolts to use when putting it on the cam? I don't know how much torque they are subjected to or if they need to be a certain size to clear all the stuff inside the case. Also, is anyone familiar with the Eljin (sp?) cams that GPR sells. They are saying they can get me a little more aggressive cam that will work perfectly without changing anything on the fuel injection. Thanks
Demick
post Oct 25 2004, 04:52 PM
Ernie made me do it!
QUOTE(Jake Raby @ Oct 25 2004, 02:41 PM)
I have never had a clearance issue with a stock pump and an aftermarket gear
Aftermarket gear isn't the problem. Problem is with an OEM gear attached to an aftermarket cam (with bolts). The bolts simply require the holes in the OEM gear to be counterbored.
Demick
Headrage   Cam Gear Replacement   Oct 25 2004, 12:25 PM
Demick   Whatever cam you buy should come with the appropri...   Oct 25 2004, 12:40 PM
Jake Raby   what oil pump are you running??   Oct 25 2004, 01:01 PM
Demick   ...   Oct 25 2004, 01:33 PM
Headrage   I was under the impression that the different size...   Oct 25 2004, 01:48 PM
Demick   The numbers indicate the size (radius) of the cam ...   Oct 25 2004, 02:11 PM
Jake Raby   I have never had a clearance issue with a stock pu...   Oct 25 2004, 04:41 PM
Demick
- Lo-Fi Version Time is now: 5th March 2026 - 10:36 AM
