Mystery oil leak |
Mystery oil leak |
Mayne |
Mar 12 2017, 09:40 PM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
Hi everyone, I picked up a 75 914 last summer and have finally gotten it running well enough to drive (which I want to do!). The problem is, a substantial oil leak that I thought I'd fixed is still there. Previously, it would spray oil from the lower drivers side at revs above idle. Not finding a clear source, I dropped the motor and resealed the oil pump, which really seemed like the issue. Motor back in now and the leak is the same. It seems to rev or crankcase pressure related, but now I'm thinking pushrod tubes or valve cover gasket. Any thoughts would be much appreciated.
I'll give a proper introduction with some photos soon. Cheers! |
ConeDodger |
Mar 12 2017, 10:06 PM
Apex killer! Group: Members Posts: 23,618 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
If you dropped the motor, you should have completely resealed it. Do it again, but this time replace all the pushrods tube seals and front and rear seals. Adjust the valves while its out on the stand as well. Check your galley plugs.
Mayne |
Mar 13 2017, 10:08 AM
If you dropped the motor, you should have completely resealed it. Do it again, but this time replace all the pushrods tube seals and front and rear seals. Adjust the valves while its out on the stand as well. Check your galley plugs. (IMG:style_emoticons/default/agree.gif) Yes, I failed on the due diligence. Will take another more thorough shot at it. |
Lo-Fi Version | Time is now: 13th June 2024 - 04:36 AM |
