Mystery oil leak |
Mystery oil leak |
Mayne |
Mar 12 2017, 09:40 PM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
Hi everyone, I picked up a 75 914 last summer and have finally gotten it running well enough to drive (which I want to do!). The problem is, a substantial oil leak that I thought I'd fixed is still there. Previously, it would spray oil from the lower drivers side at revs above idle. Not finding a clear source, I dropped the motor and resealed the oil pump, which really seemed like the issue. Motor back in now and the leak is the same. It seems to rev or crankcase pressure related, but now I'm thinking pushrod tubes or valve cover gasket. Any thoughts would be much appreciated.
I'll give a proper introduction with some photos soon. Cheers! |
brant |
Mar 13 2017, 12:34 PM
914 Wizard Group: Members Posts: 11,632 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
as far as spraying goes
I've also had the oil pressure sender loose where it actually sprayed oil. In my case it was easy to find because it was spraying up through the engine grill and onto the rear glass but most seals tend to leak and not spray (example: I just replaced my distributor seal which was causing a downward drip of oil) |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:23 PM |
