Mystery oil leak |
Mystery oil leak |
Mayne |
Mar 12 2017, 09:40 PM
Member Group: Members Posts: 254 Joined: 28-February 17 From: NM Member No.: 20,880 Region Association: None |
Hi everyone, I picked up a 75 914 last summer and have finally gotten it running well enough to drive (which I want to do!). The problem is, a substantial oil leak that I thought I'd fixed is still there. Previously, it would spray oil from the lower drivers side at revs above idle. Not finding a clear source, I dropped the motor and resealed the oil pump, which really seemed like the issue. Motor back in now and the leak is the same. It seems to rev or crankcase pressure related, but now I'm thinking pushrod tubes or valve cover gasket. Any thoughts would be much appreciated.
I'll give a proper introduction with some photos soon. Cheers! |
Mayne |
Mar 13 2017, 10:19 AM
Thanks for the suggestions. The motor will come back out and I will check and fix everything I can. I plan to start a project thread, but here are a few photos:
In the shop: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1489421966.1.jpg) Engine back in with rebuilt Webers: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1489421967.2.jpg) First drive with my brother's 69 911: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1489421967.3.jpg) Looking good with my 951 and 986: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1489421967.4.jpg) (IMG:style_emoticons/default/beerchug.gif) |
bandjoey |
Mar 13 2017, 07:27 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Thanks for the suggestions. The motor will come back out and I will check and fix everything I can. I plan to start a project thread, but here are a few photos: In the shop: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1489421966.1.jpg) Engine back in with rebuilt Webers: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1489421967.2.jpg) First drive with my brother's 69 911: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1489421967.3.jpg) Looking good with my 951 and 986: (IMG:http://www.914world.com/bbs2/uploads_offsite/i1322.photobucket.com-20880-1489421967.4.jpg) (IMG:style_emoticons/default/beerchug.gif) The answer clue is the oil breather plumbing on top of the carb air cleaner. Oil vaper hoses from both heads drain into the carbs or a breather box. If the hose is off one or both it'll blow oil everywhere. Ask people following me how I know. (IMG:style_emoticons/default/headbang.gif) |
Mayne |
Mar 14 2017, 09:04 AM
[/quote] The answer clue is the oil breather plumbing on top of the carb air cleaner. Oil vaper hoses from both heads drain into the carbs or a breather box. If the hose is off one or both it'll blow oil everywhere. Ask people following me how I know. (IMG:style_emoticons/default/headbang.gif) [/quote] I'll check into that as well, though there is no oil leaking on the top of the engine. |
Lo-Fi Version | Time is now: 2nd June 2024 - 10:20 PM |
