> Pre-clutch tube repair questions, Need some advice from welders
ThinAir
post Oct 25 2004, 09:15 PM
Best friends
I'm getting ready to fix the clutch tube on my '73. It's not just loose like your typical clutch tube repair. In my case the firewall is broken away in about a 2x3" rectangle and I can see that the rear 3-4" of tube are gone along with the firewall section.
I've got a parts car that I need to start cutting up. My plan is to cut the center tunnel along each side where it meets the floor panels so that I can remove the whole tunnel. Once I get it out I'll drill out the spot welds so that I can get to the tube from the open bottom. Once I get that far I should be able to separate the tube from the side of the tunnel so that I can move it to the '73.
So I've got 2 questions:
1) Is this a good plan?
1a) Is there a source for a "new" clutch tube that I should use instead of trying to get this one out of the parts car?
2) What kind of spot weld drill works best? Here's one type that I've seen:
McMark
post Oct 25 2004, 11:34 PM
914 Freak!
I still wouldn't replace the whole center tunnel. You could cut out the clutch tube and a section of firewall. The clutch tube is held in at three points. The firewall is one point, here is point two:
ThinAir914   Pre-clutch tube repair questions   Oct 25 2004, 09:15 PM
ThinAir914   Here's the other type that I've seen. Any...   Oct 25 2004, 09:16 PM
McMark   Re: Clutch Tube Repair: If the tube itself is sti...   Oct 25 2004, 10:16 PM
Mike9142.0   Mark The clutch tube is missing the rear most 3 t...   Oct 25 2004, 11:06 PM
ThinAir914   Here's a shot of the firewall showing the miss...   Oct 25 2004, 11:32 PM
McMark   I still wouldn't replace the whole center tunn...   Oct 25 2004, 11:34 PM
McMark   Here is point three:   Oct 25 2004, 11:35 PM
ThinAir914
- Lo-Fi Version Time is now: 5th June 2025 - 01:41 AM
