How to re-wire the Head Tempature Sensor after EFI, 1974 2.0 converted to carb |
NJTom |
Mar 18 2017, 09:14 AM
Member Group: Members Posts: 92 Joined: 16-July 14 From: NJ Member No.: 17,643 Region Association: None |
Hi we are getting ready to install a 1974 2.0 with a carburetor but don't know what to do with the Tempature Sensonr wire that comes from the motor. We found it in the EFI harness. Is there a way to directly wire and if so where does it go? Thanks in advance!
Attached thumbnail(s) |
Mark Henry |
Mar 18 2017, 09:30 AM
I do hope you mean carburetors, as it two...
The only way to be sure a single carb works proper is to test the float. Toss the carb in a lake and if it floats it's good to use. The temp sensor is only for the FI, remove it, tuck it away or snip the wire off. |
Lo-Fi Version | Time is now: 12th June 2024 - 07:17 AM |
