Starting engine out of car |
N_Jay |
Mar 18 2017, 07:06 PM
Member Group: Members Posts: 283 Joined: 2-March 16 From: Chicago NW Burbs Member No.: 19,720 Region Association: None |
What is the easiest way to start up a 914 engine out of the car.
I have an extra transmission, but seem that just the front part of an old transmission case would take a lot of weight off the whole assembly? (Anyone have such a thing.) I figured a set of short legs on the end on et engine mount bar would be spread far enough apart to be fairly stable. As for the rear, I hadn't got that far in my thinking. What I really wondered if how well it would start and run with no exhaust? I have a 1.8 and a 2.0 that are supposedly complete and want o make sure they actually run before putting one in the car. Each has full factory EFI (D-Jet and L-Jet). I also have an extra relay board, starter, etc. |
VaccaRabite |
Mar 19 2017, 08:05 PM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-1435-1489975504.1.jpg)
build a test sled so that the engine, transmission, and full exhaust can be run together. This also aids in putting the engine in the car, since you can just push the sled under th car and jack it up. I also made a simple dashboard to keep track of RPMs for initial engine run in. Zach |
Spoke |
Mar 19 2017, 08:38 PM
Jerry Group: Members Posts: 6,990 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
(IMG:http://www.914world.com/bbs2/uploads_offsite/c2.staticflickr.com-1435-1489975504.1.jpg) build a test sled so that the engine, transmission, and full exhaust can be run together. This also aids in putting the engine in the car, since you can just push the sled under th car and jack it up. I also made a simple dashboard to keep track of RPMs for initial engine run in. Zach (IMG:style_emoticons/default/agree.gif) My setup looked a lot like Zach's. Attaching the transmission case (don't need the internals) allows convenient attachment of the starter. |
Lo-Fi Version | Time is now: 5th June 2024 - 04:10 AM |
