| Chris H. |
Mar 20 2017, 08:20 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,106 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest
Hey All,
I'm working on a solution for a certain large, square German vehicle and wanted to bounce this off of the electronics gurus. Might also be helpful down the road for those who might want to do a tiptronic Boxster trans in their 914s. So...the challenge for me is that there are only a couple of automatic transmissions that are pointed in the right direction to use in the Vanagon and only one that can handle more than ~150 hp for a significant period of time. That would be the 911 tiptronic. My initial thought was to use a 964/993 trans which does not have a key driven immobilizer. Looking through the wiring diagrams I THINK I can figure out a way to run it with the stock TCU. But then I found the Megashift trans controller: Megashift! IF (big if) I am reading the directions right, it appears you need the shift solenoid configuration (probably more stuff too), and then it should be fairly easy to control. So the questions are: 1. How easy/hard do you think this would be? Seems like you program the solenoid shift config for each gear, kick down, a few other settings like idle increase, etc? 2. Since the security logic for the immobilizer is not associated with the trans itself, do you think this fully bypasses the immobilizer? Seems like it but I know very little about the tiptronic box. 3. Is there another stock automatic TCU from a VW or Audi that could be adapted to run this? EDIT: The Passat TCU MIGHT WORK. Same trans model #...ZF5HP19... (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/idea.gif) If we can make this work it could be a great thing for those wanting/needing an automatic solution. I'll give it a shot if the feedback is good. |
| Chris H. |
Mar 20 2017, 07:31 PM
Another good one! I'll need them either way if I do a 1.8t.
I traded emails with the guy who sells the controllers Falcor posted and learned (by accident) that there were two tiptronics used on the 996. All years of turbos and ALL 2002 and newer tip cars used the Mercedes trans. Prior to that the ZF5HP19 was used. Allegedly the Mercedes trans is "the best tiptronic ever made". The dilemma here is that the Passat controller MIGHT actually control the ZF trans, but the one that has a really nice ready-made system is the Mercedes trans. Mike Bellis also reminded me I want a 1999 or older TCU if I use a stock one. Seems like the safe money is the Mercedes trans and the $700 (shipped) TCU all wired up and ready to go. Anyone HAPPEN TO HAVE a ZF tiptronic trans (Boxster or 996) just laying around that I could wire a Passat TCU to? Doubt it (IMG:style_emoticons/default/lol-2.gif) . So the 1.8T SHOULD bolt right up to either of these right? I assume so since there is a guy on The Samba installing a 1.8t into a Boxster. |
Chris H. Megashift Trans Controller Mar 20 2017, 08:20 AM
Andyrew VW/Audi/Boxster is going to have relatively the sa... Mar 20 2017, 10:26 AM
Chris H. Thanks Andrew! Totally agree for a 914 I... Mar 20 2017, 11:09 AM
Andyrew
Thanks Andrew! Totally agree for a 914 I... Mar 20 2017, 01:06 PM
falcor75 http://mbturbo.com/new-722-6-gearbox-in-you-old-ca... Mar 20 2017, 11:22 AM
Chris H. That's awesome thank you! Mar 20 2017, 11:24 AM
falcor75
Another good one! I'll need them either ... Mar 20 2017, 11:50 PM
914forme
http://www.914world.com/bbs2/uploads_offsite/mat... Mar 21 2017, 08:07 PM
Andyrew
Another good one! I'll need them either ... Mar 21 2017, 08:42 AM
Chris H. Great feedback. I figured you would jump in when ... Mar 21 2017, 09:16 AM
Andyrew
Great feedback. I figured you would jump in when... Mar 21 2017, 10:27 AM
Chris H. I think I might just go for that $700 plug an... Mar 21 2017, 08:01 PM
Chris H. Yes the good news is this is the Mercedes tip, not... Mar 22 2017, 07:27 AM
914forme Chris,
Refresh on the -6 is moving forward, lots ... Mar 23 2017, 10:20 AM
Chris H. That's a nice list. I've owned quite a fe... Mar 23 2017, 09:22 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th September 2026 - 07:00 PM |
