> Transmission is whining
adolimpio
post Mar 22 2017, 06:35 PM
Art
My understanding of my recent barn find is that the transmission was rebuilt and was never driven after.
It does run great and shifts nicely, but there is a steady whine which appears to come from the transmission when cruising. At 55, while applying just enough gas to maintain speed, the whine is very annoying. It does it in all gears, the pitch increases with speed, and is quiet when coasting.
Two extra transmissions came with the car, one looking like it was a donor, and the other looks untouched. I cracked the untouched one and examined things and the ring and sychros all looked pretty good, so I swapped it in. Magically, no whine, but grinds when shifting into 1st.
So I cracked the one that whines and found that the pinion and ring gears are mismatched. One is marked 617 and the other 240. I opened the donor and found that they were also mismatched, but I now had gears from 4 sets, there were no two that matched.
So I pulled the transmission that ran quiet and its gears matched. So I swapped the gear stack between the quiet one and the whiny one, and now had a transmission with all good synchros and rings, and matching pinion and ring gears. I was very proud of myself to have identified this issue and found a resolution.
So I installed my new creation and it ran great, shifts beautifully, and still whines!
By the way, all new transmission oil installed using Red Line 75W90.
Any thoughts would be greatly appreciated!
Jeffs9146
post Mar 22 2017, 09:22 PM
Ski Bum
This is what I found when mine started whining on my 6!
adolimpio
post Mar 22 2017, 10:06 PM
Art
QUOTE(Jeffs9146 @ Mar 22 2017, 11:22 PM) *
Bummer, but all the bearings look good. It's got to be a mesh issue, and most likely the pinion / ring mesh.
adolimpio   Transmission is whining   Mar 22 2017, 06:35 PM
mark04usa   Are you sure it is a noise from the transmission? ...   Mar 22 2017, 07:13 PM
wndsrfr   It's the Ring/Pinion matchup that creates that...   Mar 22 2017, 07:28 PM
adolimpio   It's the Ring/Pinion matchup that creates tha...   Mar 22 2017, 07:52 PM
BeatNavy   It's the Ring/Pinion matchup that creates th...   Mar 23 2017, 06:52 AM
rgalla9146   [quote name='adolimpio' post='2467160' date='Mar ...   Mar 23 2017, 07:40 AM
Ansbacher   Before you get carried away with more complex solu...   Mar 22 2017, 09:09 PM
Jeffs9146   This is what I found when mine started whining on ...   Mar 22 2017, 09:22 PM
adolimpio   This is what I found when mine started whining on...   Mar 22 2017, 10:06 PM
r_towle   Does it change tone or pitch between accel and dec...   Mar 22 2017, 10:08 PM
adolimpio   Does it change tone or pitch between accel and de...   Mar 23 2017, 05:55 AM
mgphoto   Differential out of adjustment, yes gasket is shim...   Mar 23 2017, 07:44 AM
Chris H.   ^^^^ Yes it probably needs to be realigned. Have...   Mar 23 2017, 08:17 AM
adolimpio   ^^^^ Yes it probably needs to be realigned. Hav...   Mar 23 2017, 07:38 PM
adolimpio   ^^^^ Yes it probably needs to be realigned. Hav...   Sep 10 2018, 03:21 PM
ClayPerrine   ^^^^ Yes it probably needs to be realigned. Ha...   Sep 10 2018, 08:53 PM
r_towle   Check the bearing race deep in the case for the pi...   Mar 23 2017, 08:43 AM
falcor75   I have the same sort of whine in my gearbox and it...   Sep 10 2018, 10:59 PM
rjames   I have the same issue post rebuild with a new bear...   Sep 10 2018, 11:28 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 10:26 AM
