GT Flare measurements |
Puebloswatcop |
Mar 23 2017, 08:38 PM
Senior Member Group: Members Posts: 1,389 Joined: 27-December 14 From: Mineola, Texas Member No.: 18,258 Region Association: Southwest Region |
Does anyone have the measurements for installing the GT Fender flares. I have a set from AA and was just wondering where I should line them up before cutting
Root_Werks |
Mar 24 2017, 10:37 AM
Village Idiot Group: Members Posts: 8,324 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
I was reading through some of the old flare threads (mine included) and noticed I really didn't mention the importance of the front flare placement. The rear is pretty simple, just center the stock wheel opening to the flare wheel opening and you're good.
The front is a little different and can cause issues. Each set of flares can be a little different, but I remember you have to move the flares on the front forward a little. If you center wheel opening to wheel opening, the tire runs the risk of rubbing on the front. Especially if you have larger than stock tires. I think it mostly has to do with the scrub radious? Spacers used or not etc. If you tape up the front flares perfectly centered, then bolt on some 8 inch fuchs and turn the steering wheel lock-lock, you'll see what I mean. It's either forward or back, can't remember anymore. |
burton73 |
Mar 24 2017, 08:50 PM
burton73 Group: Members Posts: 3,530 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
This is what I did. Put 8 x 16 on and centered it up. The measurements from the sketch in the earlier post are what I used at first but it did not look right up front.
For the backs, I had Marty’s rear valance and that was right on. I also screwed with some GT rockers but I had 2 different sets and the lengths where different on both brands. Ended up going with AA rockers molded from his GT Bob B |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:28 PM |
