| oakdalecurtis |
Mar 26 2017, 04:42 AM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,407 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
I have two speakers on each side in front, one in the original footwell location and one in the door, wired together in series as one channel. Each pair make up the front left channel on one side and the front right channel on the other side. Then I have two speakers in the center of the backrest. One is the left rear channel and one is the right rear channel. When I balance the music out from front to back, it's really easy to hear the sound because it's coming from very close to your ears in the backrest. The front two speakers on each side compensate for their inferior position by being paired for each front channel. Don't need an amplifier. Works better than I could have hoped! (Might also notice the velcro strap around the fuse cover to keep it from being bumped off accidently)
| steuspeed |
Mar 26 2017, 06:20 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
My car came with door speakers as well. I have sourced un-cut stock door panels. I'm going back to the stock locations using shallow depth two way separates Focal VRS100. A sub mounted in the side of the console sub will add a little bass. Undecided on the sub right now. I have a few different options. Going for a stock look with decent sound. Watch for my install later this year.
Another option I considered was buying a three way separate kit. Put the 5 1/4" in the door and the mid/tweeter behind the stock grill. For a while I searched for a pair of vintage Nakamichi SP-400 speakers which contained this set-up in a plate design. Just toss out the plate and grill and use the drivers and crossover parts. I read about custom installers doing this somewhere on the web on many different cars. |
oakdalecurtis Stereo speaker placement idea you might like Mar 26 2017, 04:42 AM
Mark Henry Just in case you're wondering why the only com... Mar 26 2017, 08:40 AM
sb914
Just in case you're wondering why the only co... Mar 26 2017, 08:55 AM
Big Len
Just in case you're wondering why the only co... Mar 26 2017, 09:18 AM
bandjoey Just thinking Along the same line. Don't like ... Mar 26 2017, 08:54 AM
RickS There is that much difference in sound using the d... Mar 26 2017, 09:08 AM
Chris914n6
There is that much difference in sound using the ... Mar 26 2017, 08:00 PM
oakdalecurtis
There is that much difference in sound using the... Mar 26 2017, 08:41 PM
RickS
There is that much difference in sound using the... Mar 26 2017, 11:08 PM
GeorgeRud If you like the sound, it's your car - go for ... Mar 26 2017, 10:16 AM
oakdalecurtis
If you like the sound, it's your car - go for... Mar 26 2017, 10:58 AM
Justinp71
If you like the sound, it's your car - go fo... Mar 26 2017, 11:13 PM
oakdalecurtis Sounds good Steu. The problem with any speakers do... Mar 26 2017, 06:58 PM
ConeDodger I'm no audiophile. In fact, I'm a bit deaf... Mar 26 2017, 11:33 PM
RickS Clean install. Mar 26 2017, 11:46 PM
PancakePorsche Autosound and the 914. A challenge since 1970. Mar 28 2017, 11:25 PM
Larmo63 I have a radio block off plate and a six cylinder ... Mar 28 2017, 11:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:47 PM |
