> Stereo speaker placement idea you might like, 6 speakers, sounds great even with no roof on!
oakdalecurtis
post Mar 26 2017, 04:42 AM
Oakdalecurtis
I have two speakers on each side in front, one in the original footwell location and one in the door, wired together in series as one channel. Each pair make up the front left channel on one side and the front right channel on the other side. Then I have two speakers in the center of the backrest. One is the left rear channel and one is the right rear channel. When I balance the music out from front to back, it's really easy to hear the sound because it's coming from very close to your ears in the backrest. The front two speakers on each side compensate for their inferior position by being paired for each front channel. Don't need an amplifier. Works better than I could have hoped! (Might also notice the velcro strap around the fuse cover to keep it from being bumped off accidently)
RickS
post Mar 26 2017, 09:08 AM
There is that much difference in sound using the doors. Do a little research on enclosures and air movement in speakers and the question will answer itself. Besides, How many modern cars do not use the doors?
I won't cut my door cards but know if I did the music quality would improve dramatically. Just trying to preserve what little originality I have left.
Chris914n6
post Mar 26 2017, 08:00 PM
Jackstands are my life.
QUOTE(RickS @ Mar 26 2017, 08:08 AM) *
First off, doors are not the best place, just the most practical. Speakers far out by the feet are good for imaging. I've had good results putting the tweets by the windshield.
Second, the good sounding speakers are housed in tuned enclosures, not just screwed to the unsealed door's frame.
Third, I prefer the live concert sound, so no rear speakers unless it's subs, because bass is non-directional.
oakdalecurtis
post Mar 26 2017, 08:41 PM
Oakdalecurtis
QUOTE(Chris914n6 @ Mar 26 2017, 07:00 PM) *
I guess I'm just getting old and deaf, cause the louder and closer the music is to my ears, the better it sounds! (IMG:style_emoticons/default/piratenanner.gif)
oakdalecurtis   Stereo speaker placement idea you might like   Mar 26 2017, 04:42 AM
Mark Henry   Just in case you're wondering why the only com...   Mar 26 2017, 08:40 AM
sb914   Just in case you're wondering why the only co...   Mar 26 2017, 08:55 AM
Big Len   Just in case you're wondering why the only co...   Mar 26 2017, 09:18 AM
bandjoey   Just thinking Along the same line. Don't like ...   Mar 26 2017, 08:54 AM
RickS   There is that much difference in sound using the d...   Mar 26 2017, 09:08 AM
Chris914n6   There is that much difference in sound using the ...   Mar 26 2017, 08:00 PM
oakdalecurtis   There is that much difference in sound using the...   Mar 26 2017, 08:41 PM
RickS   There is that much difference in sound using the...   Mar 26 2017, 11:08 PM
GeorgeRud   If you like the sound, it's your car - go for ...   Mar 26 2017, 10:16 AM
oakdalecurtis   If you like the sound, it's your car - go for...   Mar 26 2017, 10:58 AM
Justinp71   If you like the sound, it's your car - go fo...   Mar 26 2017, 11:13 PM
steuspeed   My car came with door speakers as well. I have sou...   Mar 26 2017, 06:20 PM
oakdalecurtis   Sounds good Steu. The problem with any speakers do...   Mar 26 2017, 06:58 PM
ConeDodger   I'm no audiophile. In fact, I'm a bit deaf...   Mar 26 2017, 11:33 PM
RickS   Clean install.   Mar 26 2017, 11:46 PM
PancakePorsche   Autosound and the 914. A challenge since 1970.   Mar 28 2017, 11:25 PM
Larmo63   I have a radio block off plate and a six cylinder ...   Mar 28 2017, 11:42 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 01:47 PM
