AndrewBlyholder |
Member ![]() ![]() Group: Members Posts: 112 Joined: 20-September 04 From: Richmond, CA Member No.: 2,791 ![]() |
I had my alternator belt flip over at an autocross last weekend. Anyone else ever seen this?
Belt was on the fan and alternator pulleys, just as it should be, but the teeth were facing outward. It had flipped itself inside out! Tension was good. Adjuster bolt still tight. Discovered this after the motor had started cutting out and finally stopped on course. The cause for that was the electrical connections coming off of the starter motor. Those connections include the power supply to the CDI box. So the engine quit due to no spark. The nut had backed off and fell off. (User error on that. Could'a swore I'd torqued that nut...) My theory is that, as the electrical connection was shaking loose, the engine was cutting in and out, and the torque variations from that process caused the fan belt to jump around enough to flip over. But that's just my theory. Anyone else had any experience with a problem like this? Thanks, Andrew Blyholder |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,009 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
Andrew,
back in the 90's we used to club race a 4 cylinder it too, would throw the belt high rpm, and especially if there was ever a missed shift where the motor would rev very fast.... the real problem is likely a worn pulley that doesn't "grip" the belt as well as it should. I've seen them flip and more commonly, I've seen them just throw off but here is a cheap thing to try. take a new belt. put it into a zip lock bag soak with with wd40 or some lubricant of your choice let it soak a minimum of over night. dry it off with a rag and install, but not too tight. what happened for me: if the motor rpm was really high or something occurred that may throw off the belt, the belt will then just temporarily slip... the slip is enough that the belt doesn't throw off give it a try if it doesn't work, your out a 5$ belt but I've seen it work! brant |
Lo-Fi Version | Time is now: 4th July 2025 - 09:12 PM |
