> Adjusting Fuel Pressure for Better Running Engine, 1.7 Engine Performance
R Shaff
post Mar 28 2017, 05:06 AM
I've read some helpful things here while helping with my brother's '72 914. I think I've learned something new and thought I'd share it with you guys.
This car has the original engine and FI system, though the ignition system has been updated and is electronic. The car wasn't running well, and the local shop my brother uses said he should do a carb conversion, costing over $4,000. We looked online and found some good write-ups that recommended keeping the FI system. I've worked on many cars and restored one, so I thought I'd try to get the car running well enough with the original system.
The compression and ignition checked out fine. We adjusted the valves (of course). We tested and then replaced 3 injectors, and the CHT sensor. I put the fuel pressure at 28 psi, per spec. Static tests of the manifold pressure sensor came out fine. A cigar smoke test showed no intake leaks. We cleaned and adjusted the TPS, and then finally changed the TPS contact plate and adjusted the arm (when the car just wouldn't run right). All the other components checked out fine, using tests I found online.
The result? The engine fired right up, with a good idle. But when driving it lacked power, and the higher the rpm the less it wanted to pull. (Not right for a Porsche.) It felt like the timing wasn't advancing, or that the engine just wasn't getting enough air or gas in the right balance.
Other than buying a replacement MPS or computer, I was running out of ideas to try. One of good things about carbs is that they are adjustable. One of the challenging things about these old open-loop FI systems is that they are not really designed to be adjusted much, or at all. Repair is usually a process of testing and replacing components. But this car sure felt like it needed some kind of adjustment.
One of the odd things about this car, in my experience, is that the fuel pressure regulator IS adjustable. So that's what we tried, just using seat-of-the-pants performance as the indicator. We dialed the pressure down a turn and things got worse. Then we turned the pressure up, one turn at a time, and voila! As we did the car ran better and better. Now it pulls in the upper ranges like it should, much like it used to.
Now we're going to buy a 4th injector of the same type and adjust the pressure again as needed. (Now that we know we can adjust the whole system.) Perhaps that will make it run better still.
I haven't read that anywhere(about adjusting fuel pressure to get the engine to run better) so I thought it might help someone else who is struggling with these old Bosch systems.
Happy motoring!
Richard
jim_hoyland
post Mar 29 2017, 05:13 AM
Get that VIN ?
Am I correct ? Certain year Pressure Regulators at NOT adjustable ?
R Shaff   Adjusting Fuel Pressure for Better Running Engine   Mar 28 2017, 05:06 AM
Minerva's 914   Thanks Richard for the writeup. When Fat Performan...   Mar 28 2017, 08:21 AM
R Shaff   Thanks Richard for the writeup. When Fat Performa...   Mar 28 2017, 08:48 AM
Minerva's 914   Thanks Richard for the writeup. When Fat Perform...   Mar 28 2017, 05:18 PM
boxsterfan   Did you clean your distributor? And put of drop o...   Mar 28 2017, 12:08 PM
R Shaff   Did you clean your distributor? And put of drop ...   Mar 28 2017, 12:15 PM
r_towle   Did you clean your distributor? And put of drop...   Mar 29 2017, 09:09 PM
914sgofast2   I agree that adjusting the fuel pressure works. Af...   Mar 28 2017, 12:11 PM
914_teener   I agree that adjusting the fuel pressure works. A...   Mar 28 2017, 04:47 PM
mark04usa   Timing set at 27 deg advance (with vac lines disco...   Mar 28 2017, 01:25 PM
R Shaff   Timing set at 27 deg advance (with vac lines disc...   Mar 28 2017, 05:12 PM
jim_hoyland   Several years ago a local gave me a ride in his ...   Mar 28 2017, 01:26 PM
PancakePorsche   With all the alcohol in what they call gas, you ne...   Mar 28 2017, 10:57 PM
jim_hoyland   Am I correct ? Certain year Pressure Regulators at...   Mar 29 2017, 05:13 AM
Minerva's 914   I need to buy a fuel pressure gauge. What model do...   Mar 29 2017, 08:32 PM
914_teener   I need to buy a fuel pressure gauge. What model d...   Mar 29 2017, 10:08 PM
Minerva's 914   I need to buy a fuel pressure gauge. What model ...   Mar 30 2017, 04:36 AM
BeatNavy   By chance you have a link to buy it? (in other w...   Mar 30 2017, 05:28 AM
Minerva's 914   By chance you have a link to buy it? (in other ...   Mar 30 2017, 12:42 PM
R Shaff   OK. I'll check and prob clean the advance mech...   Mar 31 2017, 06:19 AM
Racer Chris   You should be tuning by adjusting the MPS not the ...   Mar 31 2017, 09:26 AM
brant   You should be tuning by adjusting the MPS not the...   Mar 31 2017, 11:56 AM
Rand   You should be tuning by adjusting the MPS not th...   Mar 31 2017, 12:06 PM
Minerva's 914   [quote name='brant' post='2470410' date='Mar 31 2...   Mar 31 2017, 05:30 PM
914_teener   You said it was a stock motor. :stromberg: You ...   Mar 31 2017, 06:22 PM
Minerva's 914   You said it was a stock motor. :stromberg: You...   Mar 31 2017, 09:33 PM
r_towle   If you increased the displacement you need to tune...   Mar 31 2017, 06:27 PM
R Shaff   If you increased the displacement you need to tun...   Apr 1 2017, 06:06 AM
R Shaff   Thank you, all. I appreciate the input. My rea...   Apr 1 2017, 06:03 AM
r_towle   The weights stick when the old grease gets hot, th...   Apr 1 2017, 03:21 PM
r_towle   Also, the ONLY vacuum line required to the plenum ...   Apr 1 2017, 03:26 PM
R Shaff   Also, the ONLY vacuum line required to the plenum...   Apr 2 2017, 03:54 PM
The Cabinetmaker   The cap'n would have thoroughly chewed ass her...   Apr 1 2017, 05:58 PM
R Shaff   The cap'n would have thoroughly chewed ass he...   Apr 2 2017, 04:16 PM
The Cabinetmaker   Buy the mps tuning kit from Chris Foley. I believe...   Apr 2 2017, 04:52 PM
- Lo-Fi Version Time is now: 12th July 2025 - 11:28 AM
