| forrestkhaag |
Mar 29 2017, 01:44 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Does anyone have experience in tightening the 36mm nut on the stock oil line leaving the bottom of the 914-6 stock oil tank ;and.... if so,..... with what tool? A crow's foot may get there but I don't know if that size exists. Also, there has to be a calculation to convert torque from a straight line tool (a socket perhaps) to an offset crow's foot tool.
Or maybe slice up a 36mm socket and weld a bar to the outer surface to allow some purchase on that infernal nut. Another PITA (IMG:style_emoticons/default/sheeplove.gif) option is to remove the tank yet again and tighten the nut and hope to the almighty that it is in the right relationship to the inner fender when reinstalled... Also confounding the situation is that I have a chart of torque settings for the 911 SC but no mention of the torque values required of these oil line fittings to the engine, tank, and to each other. Any Clues Robert? I have to make an effort now I just to be serious, oh yeah Nobody's gonna give you the benefit of the doubt, oh my Every time I pick a paper up it's harder to believe the news, oh yeah I'm gonna have to shake it up and twist and shout, oh my... looking for clues |
| GeorgeRud |
Mar 29 2017, 02:44 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
It's been years since I had to remove the oil tank on my -6, but I seem to remember that I used my open end 36mm wrench on the fitting (the same one I use to separate the oil lines when changing the oil). It was tight but doable (in my recollection) from underneath the car. I don't think there is an actual torque value for that fitting, just snug enough to prevent leaking.
forrestkhaag Quoth the raven nevermore Mar 29 2017, 01:44 PM
mepstein Yes Mar 29 2017, 01:46 PM
PanelBilly :agree: Mar 29 2017, 02:01 PM
KELTY360 :ttiwwp: Mar 29 2017, 02:04 PM
Perry Kiehl The easiest way is to put that on before you insta... Mar 29 2017, 03:32 PM
jd74914 A 36mm crowfoot is maybe $10 [online] and fac... Mar 29 2017, 03:33 PM
aturboman Hi Forrest I have a thin section 911 oil line wren... Mar 29 2017, 03:41 PM
forrestkhaag I will check out the crow's foot option for th... Mar 29 2017, 04:07 PM
76-914 Perry's tip seems like sound advice. Put a dro... Mar 29 2017, 05:42 PM
Larmo63 This is what you need.....
Mar 29 2017, 07:39 PM
scallyk9
Uh-huh, nice, but ... Mar 29 2017, 08:23 PM
forrestkhaag You poor bastards dont know the meaning of poor. ... Mar 29 2017, 08:07 PM
forrestkhaag My tool is ambidextrous...... Mar 29 2017, 08:25 PM
Steve I made a tool that works great. Just used it last... Mar 29 2017, 09:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th March 2026 - 12:39 PM |
