| falcor75 |
Mar 28 2017, 11:28 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia
I had two rear hubs done but none of the holes for the brake disc mounting screws were lined up and the hackjob of drilling and countersinking new holes in the brake disc was something I didnt like.
The mounting holes in the hub are oriented 180 degrees apart from what I can tell. The holes in the 914-6 brake disc are more like 175/185 degrees apart. Is there any particular way that is better than the others for orientation of the hub vs the brake disc? I want to be able to give as clear instructions as possible to the machine shop. (IMG:style_emoticons/default/confused24.gif) |
| mgphoto |
Mar 29 2017, 12:17 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,493 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
If you don't put the screws, any of the disks could move on assembly making that wheel out of balance.
I decided to source original parts instead of "modified" ones. Mike |
| mepstein |
Mar 29 2017, 04:31 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,903 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
If you don't put the screws, any of the disks could move on assembly making that wheel out of balance. I decided to source original parts instead of "modified" ones. Mike Move where? What will two little screws do that five large studs torqued down to 90 ft lbs. won't? |
| mgphoto |
Mar 29 2017, 04:37 PM
If you don't put the screws, any of the disks could move on assembly making that wheel out of balance. I decided to source original parts instead of "modified" ones. Mike Move where? What will two little screws do that five large studs torqued down to 90 ft lbs. won't? "On assembly" you trust some mook at Discount Tire Express to make sure your disks are centered ? You might take the time to do it right. Mike |
| bdstone914 |
Mar 30 2017, 08:09 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,375 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
"On assembly" you trust some mook at Discount Tire Express to make sure your disks are centered ? You might take the time to do it right. Mike [/quote] The discs center on the back side to the hub. Screws have no effect on centering, safety, or function. Your on the wrong track on this one Mike. |
| Mark Henry |
Mar 30 2017, 09:00 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
QUOTE "On assembly" you trust some mook at Discount Tire Express to make sure your disks are centered ? You might take the time to do it right. Mike The discs center on the back side to the hub. Screws have no effect on centering, safety, or function. Your on the wrong track on this one Mike. The screws are more of a ease of assembly deal. Likely on the factory floor the rotors were installed and it was several workers down the line before calipers went on. The factory just wanted a quick way of holding them in place so they wouldn't fall off and on the floor. Taking the screws off can be a pain if they seize on. |
falcor75 Rear hub conversion... Mar 28 2017, 11:28 AM
bdstone914
I had two rear hubs done but none of the holes fo... Mar 29 2017, 07:57 AM
Mark Henry
Or you can forget the screws as the rotor is goi... Mar 29 2017, 08:07 AM
cgnj Yes, not required. When I did my rear conversion I... Mar 29 2017, 08:23 AM
r_towle No screw required.
Only you will know. Mar 29 2017, 09:10 AM
[quote name='mepstein' post='2469763' date='Mar 2... Mar 29 2017, 05:00 PM
mgphoto
[quote name='mepstein' post='2469763' date='Mar ... Mar 29 2017, 05:05 PM
jmitro
The discs center on the back side to the hub. Sc... Mar 30 2017, 11:15 AM
jmitro no it won't. installing the wheel with 4 (or 5... Mar 29 2017, 01:09 PM
mgphoto
no it won't. installing the wheel with 4 (or ... Mar 29 2017, 02:24 PM
jd74914
The disk will be held in place by the sandwich of... Mar 29 2017, 03:37 PM
mgphoto
The disk will be held in place by the sandwich o... Mar 29 2017, 04:09 PM
914Sixer I would also recommend getting centering rings fro... Mar 29 2017, 03:25 PM
Spoke I had the same issue using 911 rotors with redrill... Mar 29 2017, 04:36 PM
Spoke I don't think the brake rotor could get out of... Mar 30 2017, 06:46 AM
Bartlett 914 It all depends on how loose the rotor fits over th... Mar 30 2017, 09:42 AM![]() ![]() |
Lo-Fi Version | Time is now: 12th September 2026 - 09:57 AM |
