> Rear hub conversion..., aligning the holes...
falcor75
post Mar 28 2017, 11:28 AM
I had two rear hubs done but none of the holes for the brake disc mounting screws were lined up and the hackjob of drilling and countersinking new holes in the brake disc was something I didnt like.
The mounting holes in the hub are oriented 180 degrees apart from what I can tell. The holes in the 914-6 brake disc are more like 175/185 degrees apart.
Is there any particular way that is better than the others for orientation of the hub vs the brake disc?
I want to be able to give as clear instructions as possible to the machine shop. (IMG:style_emoticons/default/confused24.gif)
Bartlett 914
post Mar 30 2017, 09:42 AM
It all depends on how loose the rotor fits over the studs. If you hold the rotor against the hub and can still move the rotor around, you may have a centering problem. I saw this last year. The rotor actually hit the inside of the caliper it ran out of round so much. If there is no play, then you have no worry.
falcor75   Rear hub conversion...   Mar 28 2017, 11:28 AM
bdstone914   I had two rear hubs done but none of the holes fo...   Mar 29 2017, 07:57 AM
Mark Henry   Or you can forget the screws as the rotor is goi...   Mar 29 2017, 08:07 AM
cgnj   Yes, not required. When I did my rear conversion I...   Mar 29 2017, 08:23 AM
r_towle   No screw required. Only you will know.   Mar 29 2017, 09:10 AM
mgphoto   If you don't put the screws, any of the disks ...   Mar 29 2017, 12:17 PM
mepstein   If you don't put the screws, any of the disks...   Mar 29 2017, 04:31 PM
mgphoto   If you don't put the screws, any of the disk...   Mar 29 2017, 04:37 PM
mepstein   [quote name='mepstein' post='2469763' date='Mar 2...   Mar 29 2017, 05:00 PM
mgphoto   [quote name='mepstein' post='2469763' date='Mar ...   Mar 29 2017, 05:05 PM
bdstone914   ] "On assembly" you trust some mook at D...   Mar 30 2017, 08:09 AM
Mark Henry   The discs center on the back side to the hub. ...   Mar 30 2017, 09:00 AM
jmitro   The discs center on the back side to the hub. Sc...   Mar 30 2017, 11:15 AM
jmitro   no it won't. installing the wheel with 4 (or 5...   Mar 29 2017, 01:09 PM
mgphoto   no it won't. installing the wheel with 4 (or ...   Mar 29 2017, 02:24 PM
jd74914   The disk will be held in place by the sandwich of...   Mar 29 2017, 03:37 PM
mgphoto   The disk will be held in place by the sandwich o...   Mar 29 2017, 04:09 PM
914Sixer   I would also recommend getting centering rings fro...   Mar 29 2017, 03:25 PM
Spoke   I had the same issue using 911 rotors with redrill...   Mar 29 2017, 04:36 PM
Spoke   I don't think the brake rotor could get out of...   Mar 30 2017, 06:46 AM
Bartlett 914   It all depends on how loose the rotor fits over th...   Mar 30 2017, 09:42 AM
- Lo-Fi Version Time is now: 12th September 2026 - 09:57 AM
