| gspreeman |
Mar 30 2017, 03:54 PM
Newbie ![]() Group: Members Posts: 22 Joined: 16-November 10 From: South Orange, NJ Member No.: 12,395 Region Association: None |
Next step in diagnosing my low beam driver's side headlight that won't work, which spade on the headlight switch powers up the low beam on the driver's side? Actually, is there a dedicated spade for it? For all I know, when you pull on the headlight switch, it powers up the headlights with just one spade.
| vin man |
Mar 30 2017, 04:09 PM
Member ![]() ![]() Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
Next step in diagnosing my low beam driver's side headlight that won't work, which spade on the headlight switch powers up the low beam on the driver's side? Actually, is there a dedicated spade for it? For all I know, when you pull on the headlight switch, it powers up the headlights with just one spade. On my 72, spade 56 on the headlight switch is what sends power to the headlight relay. Depending on which position the relay is in, the high beam or low beam will come on. On my original relay, spade 56a was the low beam side and spade F was the high beam. Once I went to a new relay, the spades had different connect points. Troubleshooting my headlights |
gspreeman Headlight Switch - 1975 - which spade is low beam dr side Mar 30 2017, 03:54 PM
jcd914 Power for the headlight is a single wire (red w/wh... Mar 30 2017, 06:58 PM![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 02:43 AM |
