Problem with fuel injection, Advice needed |
cal914 |
Mar 28 2017, 03:04 PM
Member Group: Members Posts: 319 Joined: 12-April 12 From: United Kingdom Member No.: 14,366 Region Association: None |
Hi there
Just put our 1970 914 back to fuel injection from carbs and it purred for the first 30 minutes in slow moving traffic but then it began to cough and then was quickly nearly kangarooing down the street. It was fine idling but trying to pull away and driving it, it sounded as though it was misfiring or coughing or not running on all cylinders. What's the checklist for trying to solve the problem? Thanks! |
injunmort |
Mar 31 2017, 06:03 PM
Senior Member Group: Members Posts: 1,024 Joined: 12-April 10 From: sugarloaf ny Member No.: 11,604 Region Association: North East States |
just something else to consider, the coil. when the coil starts to breakdown, they run fine cold, as they heat up, they expand and the windings separate, causing the condition you describe. try a coil swap and see if things change.
Lo-Fi Version | Time is now: 7th June 2024 - 12:39 PM |
