| Tastyplacement |
Apr 3 2017, 08:54 PM
Newbie ![]() Group: Members Posts: 39 Joined: 31-August 16 From: Austin, TX Member No.: 20,358 Region Association: MidAtlantic Region |
Oh man, I am up a creek. I am installing the Tangerine cable system and one carb is fine, but after I installed the pulley, one carb is binding and will ALMOST return to idle, but it is binding on something. The carbs are rebuilt but I did not replace throttle shaft bearings. The carb works fine throughout it's range of motion except for the last 10 degrees where it should return to idle. If you let it snap shut, it shuts, but if you ease off, it sticks.
I have had this freaking carb and cable system apart and back together 5 times and don't know where to look. Carbs are Made in Spain 40 IDF |
| ljubodraz |
Apr 4 2017, 05:18 AM
Member ![]() ![]() Group: Members Posts: 64 Joined: 4-May 14 From: Chicagoland Member No.: 17,312 Region Association: Upper MidWest |
I had something similar happen to one of my Dellorto carbs after a soak and rebuild. A few squirts of PB Blaster on the throttle shaft ends and springs freed it right up. In my case, I believe it was the springs. Even if it's your bearings, I would first give this a patient try hoping it will penetrate the bearing seals.
Tastyplacement Help with Weber Carb not returning to idle Apr 3 2017, 08:54 PM
Elliot Cannon
Oh man, I am up a creek. I am installing the Tang... Apr 3 2017, 10:31 PM
michael7810 Had the identical situation on my car after carb r... Apr 4 2017, 06:28 AM
cgnj I have new sealed bearings from rebuilding my dell... Apr 4 2017, 06:50 AM
rfinegan I had to shim or remove shims my cam wheels to get... Apr 4 2017, 07:02 AM
Racer Chris I can think of a several possibilities.
1) the cab... Apr 4 2017, 07:19 AM
Tastyplacement Ok, thank you guys. To finish this off, here is wh... Apr 4 2017, 09:45 AM
Racer Chris
Regarding the Tangerine cable system, you HAVE t... Apr 4 2017, 09:48 AM
stugray When you rebuilt the carbs did you take the butter... Apr 4 2017, 10:17 AM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 04:55 PM |
