> Help with Weber Carb not returning to idle
Tastyplacement
post Apr 3 2017, 08:54 PM
Oh man, I am up a creek. I am installing the Tangerine cable system and one carb is fine, but after I installed the pulley, one carb is binding and will ALMOST return to idle, but it is binding on something. The carbs are rebuilt but I did not replace throttle shaft bearings. The carb works fine throughout it's range of motion except for the last 10 degrees where it should return to idle. If you let it snap shut, it shuts, but if you ease off, it sticks.
I have had this freaking carb and cable system apart and back together 5 times and don't know where to look. Carbs are Made in Spain 40 IDF
ChrisFoley
post Apr 4 2017, 07:19 AM
I am Tangerine Racing
I can think of a several possibilities.
1) the cable alignment into the pulley groove is important. Allowing the cable to drag on one side of the groove may add enough friction to overcome the springs, which are at their weakest when the throttle is closed. Thin washers on the cable support bolts are sometimes needed to finalize the alignment.
2) The could be a burr on the backside of the throttle stop plate where it was drilled for the pulley alignment pin.
3) Overtightening the nut on the throttle shaft may be enough to make the throttle shaft drag.
- Lo-Fi Version Time is now: 13th March 2026 - 03:02 PM
