> Adding an Oil Cooler to my healthy 4, What should I consider?
Joseph Mills
post Oct 26 2004, 07:47 PM
on a Sonoma diet now...
Now that my engine is back together with higher compression I need to consider some additional cooling.
In 80-90 degrees ambient temps, at 3800rpm highway, it runs 200-210-215. So next summer in mid to high 90's, it's going to need some help.
I really don't want to install a cooler up front. But are there any alternatives? Rear fender well? Rear trunk with cutout? Engine bay?
Any specifics or brand models would be most helpful. Pics?
Joseph Mills
post Oct 26 2004, 10:37 PM
QUOTE(dmenche914 @ Oct 26 2004, 08:36 PM)
The temp might be a bit on the high side.  I have found that the temp gages (not so much a sender issue) can vary a good amount.  So before going to the trouble of adding a cooler, go ahead and confirm your temp reading if you haven't already.......
dmenche914,
Thanks for all the tips - you covered a lot of good ground. However, I have pretty well been thru all of them. I haven't finished all my tin issues yet but am getting there. Your list made me mentally double check what I have done.
My car runs 180-200 around town, which comprises most of my driving, other than autocrossing (where high temps are not a problem). One could argue I don't really need a cooler.
But for those times when I do want to kick it on the highway, or participate in a few DE's next year, I think I will need it and I do want the added protection.
Thanks! (IMG:style_emoticons/default/beer.gif)
Joseph Mills   Adding an Oil Cooler to my healthy 4   Oct 26 2004, 07:47 PM
Demick   I'm considering this one for mine. Mounted un...   Oct 26 2004, 08:09 PM
dmenche914   The temp might be a bit on the high side. I have ...   Oct 26 2004, 08:36 PM
Joseph Mills     Oct 26 2004, 09:33 PM
Demick   Yes, under the rear trunk to the passenger side of...   Oct 26 2004, 10:23 PM
Joseph Mills     Oct 26 2004, 10:44 PM
!   Yup...check the temp....use a hand held pyrometer....   Oct 26 2004, 10:50 PM
Joseph Mills     Oct 26 2004, 11:19 PM
!   My dad had her first..... <_<   Oct 26 2004, 11:22 PM
Joseph Mills     Oct 27 2004, 12:11 AM
bernbomb914   I installed one under the rear trunk with a fan. I...   Oct 27 2004, 12:49 AM
bob91403
- Lo-Fi Version Time is now: 13th September 2026 - 01:33 PM
