> Adding an Oil Cooler to my healthy 4, What should I consider?
Joseph Mills
post Oct 26 2004, 07:47 PM
on a Sonoma diet now...
Now that my engine is back together with higher compression I need to consider some additional cooling.
In 80-90 degrees ambient temps, at 3800rpm highway, it runs 200-210-215. So next summer in mid to high 90's, it's going to need some help.
I really don't want to install a cooler up front. But are there any alternatives? Rear fender well? Rear trunk with cutout? Engine bay?
Any specifics or brand models would be most helpful. Pics?
bob91403
post Oct 27 2004, 04:12 AM
QUOTE(bernbomb914 @ Oct 26 2004, 11:49 PM)
I installed one under the rear trunk with a fan. I built a bracket to tilt it toward the wheel well were the air might be cooler. I havent driven it yet to test its effectiveness. and will install a DTM with a cooler built into it when jake gets to it.
Bernie
(IMG:style_emoticons/default/agree.gif) Screw the oil cooler. Jake's DTM is the only way to go. Add your name to the list. (IMG:style_emoticons/default/boldblue.gif)
Joseph Mills   Adding an Oil Cooler to my healthy 4   Oct 26 2004, 07:47 PM
Demick   I'm considering this one for mine. Mounted un...   Oct 26 2004, 08:09 PM
dmenche914   The temp might be a bit on the high side. I have ...   Oct 26 2004, 08:36 PM
Joseph Mills     Oct 26 2004, 09:33 PM
Demick   Yes, under the rear trunk to the passenger side of...   Oct 26 2004, 10:23 PM
Joseph Mills     Oct 26 2004, 10:44 PM
!   Yup...check the temp....use a hand held pyrometer....   Oct 26 2004, 10:50 PM
Joseph Mills     Oct 26 2004, 11:19 PM
!   My dad had her first..... <_<   Oct 26 2004, 11:22 PM
Joseph Mills     Oct 27 2004, 12:11 AM
bernbomb914   I installed one under the rear trunk with a fan. I...   Oct 27 2004, 12:49 AM
bob91403
- Lo-Fi Version Time is now: 13th September 2026 - 01:33 PM
