how much bar is to much bar? |
ottox914 |
Oct 26 2004, 04:37 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I 'll first describe how the '14 is set up, then what I'm thinking and why, then you guys take it from there: Front: 21mm front T bars, 19mm weltmeister sway bar, set about 1/4 in from full soft, koni oil (911) sport adjustables in shortened housings, usually run at 1/2 turn in from full soft. Allignment as much neg as I can get, which is about 1 1/2 per side, 1/8 total toe out, caster at high end of factory specs. Back: Koni gas sports, (914), run full soft, 175# springs, threaded adjusters, no rear sway bar, no toe and no neg camber. Koni competition bump stops all the way around. Stock 15 x 5.5 rims w/Azenis, going to kuhmo or hoosier for next season, on either factory rims or 6.0 panasports. Rack spacers up front. Lowered to about 2-2.5" of travel for front struts before hitting the bump stops, back end lowered to corner balance to 49/51 diagonals. Open diff. 2.0 motor, soon to be kitcarlson'd, kerry hunter header w/supertrapp, "custom" (home-made) cold air kit, basically a K & N mounted on some pvc on top of the throttle body that sits right under the engine lid mesh w/the rain tray out.
I like the way it handles, in specific, the throttle lift oversteer at higher speeds to rotate around a cone. The car will be DSP for next season. Don't like the body roll. I think from seeing photos there is too much. Plan of attack? I have always thought getting spring rates right was the first step, then sort the F/R balance with the sway bars, and fine tune at the track with shocks and air pressures, in that order. Here's what I'm thinking- go to the 23mm front sway bar, adjustable drop links to make sure there is no pre-load, add the (?) 18mm rear adjustable bar. Increase both bars a similar amount to try to retain the front/rear balance, and hopefully lose some body roll in the deal. Maybe go back to the 150# springs sitting in the garage. Use is auto x, no lapping or road course stuff. (yet) So, how about it? Anyone been there/done that? Most of the folks I've talked to locally stay away from a rear bar. I like the F/R balance the car currently has, and know how to fine tune it w/shocks/tire pressures for the conditions of the day. When I have tried to tighten up on the front bar, it just seems to become a pushing machine, and with the shocks set other than noted, it rides like a dump truck. Just gotta get rid of some roll, or just get used to it. waddya all think? |
Mueller |
Oct 27 2004, 04:32 PM
your 19mm bar = solid
trekkors 31mm bar = hollow (available in 27mm I think as well) SmartRacing my 25mm bar = hollow (Tarett Engineering) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:02 AM |
