| RSR |
Apr 22 2017, 03:07 PM
Newbie ![]() Group: Members Posts: 14 Joined: 20-April 17 From: Occidental Member No.: 21,036 Region Association: Northern California |
I'd like to introduce my self, my name is Donald this is my first post hello to all my mid engine Porsche brothers and sisters. I've joined this forum because I'm in need of help trying to make my 1998 986 pass smog in Ca. I know there's been a lot of guys running Subaru power on here. (I found this car half done while looking for a 914 to do a Subaru transplant) it was to cheap and ran and drove so here I am. I'm running a 2000 ej25 sohc adapted to my stock 986 G86/00 5 speed. The Porsche gear box has no neutral switch so I keep getting a P01597 code and then that leads to idle control faults as well. Any help would be very much appreciated.
| zipedadoo |
Apr 22 2017, 08:16 PM
Member ![]() ![]() Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
Have you ever used one of these, or something similar?
http://www.ebay.com/itm/MEA9161-G-LIMIT-SW...C-/282346461340 It wouldn't take much to fab up a temporary or permanent bracket to make it work like a neutral switch. |
RSR Subaru convertion Apr 22 2017, 03:07 PM
Mueller
I'd like to introduce my self, my name is Don... Apr 22 2017, 06:43 PM
RSR It is two wires I have them hooked to the clutch s... Apr 22 2017, 07:07 PM
Mueller It might only want to see the switch closed at or ... Apr 22 2017, 07:35 PM
RSR I have the diagram it works correctly for about a ... Apr 22 2017, 07:49 PM
RSR I'm not sure if the ecu is auto or manual I th... Apr 22 2017, 08:03 PM
RSR I just looked at my wiring diagram again and trace... Apr 22 2017, 09:46 PM
Mike Bellis Connect a bogus switch through the clutch pedal sw... Apr 22 2017, 11:45 PM
RSR
Connect a bogus switch through the clutch pedal s... Apr 23 2017, 02:31 PM
76-914 Depends upon which Subaru trans. Some use N/O neut... Apr 23 2017, 05:29 PM
RSR
Depends upon which Subaru trans. Some use N/O neu... Apr 24 2017, 01:10 PM
zipedadoo normally open / normally closed Apr 24 2017, 01:24 PM
Chris914n6 First off, couldn't find that code you referen... Apr 24 2017, 07:42 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 02:49 PM |
