how much bar is to much bar? |
ottox914 |
Oct 26 2004, 04:37 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
I 'll first describe how the '14 is set up, then what I'm thinking and why, then you guys take it from there: Front: 21mm front T bars, 19mm weltmeister sway bar, set about 1/4 in from full soft, koni oil (911) sport adjustables in shortened housings, usually run at 1/2 turn in from full soft. Allignment as much neg as I can get, which is about 1 1/2 per side, 1/8 total toe out, caster at high end of factory specs. Back: Koni gas sports, (914), run full soft, 175# springs, threaded adjusters, no rear sway bar, no toe and no neg camber. Koni competition bump stops all the way around. Stock 15 x 5.5 rims w/Azenis, going to kuhmo or hoosier for next season, on either factory rims or 6.0 panasports. Rack spacers up front. Lowered to about 2-2.5" of travel for front struts before hitting the bump stops, back end lowered to corner balance to 49/51 diagonals. Open diff. 2.0 motor, soon to be kitcarlson'd, kerry hunter header w/supertrapp, "custom" (home-made) cold air kit, basically a K & N mounted on some pvc on top of the throttle body that sits right under the engine lid mesh w/the rain tray out.
I like the way it handles, in specific, the throttle lift oversteer at higher speeds to rotate around a cone. The car will be DSP for next season. Don't like the body roll. I think from seeing photos there is too much. Plan of attack? I have always thought getting spring rates right was the first step, then sort the F/R balance with the sway bars, and fine tune at the track with shocks and air pressures, in that order. Here's what I'm thinking- go to the 23mm front sway bar, adjustable drop links to make sure there is no pre-load, add the (?) 18mm rear adjustable bar. Increase both bars a similar amount to try to retain the front/rear balance, and hopefully lose some body roll in the deal. Maybe go back to the 150# springs sitting in the garage. Use is auto x, no lapping or road course stuff. (yet) So, how about it? Anyone been there/done that? Most of the folks I've talked to locally stay away from a rear bar. I like the F/R balance the car currently has, and know how to fine tune it w/shocks/tire pressures for the conditions of the day. When I have tried to tighten up on the front bar, it just seems to become a pushing machine, and with the shocks set other than noted, it rides like a dump truck. Just gotta get rid of some roll, or just get used to it. waddya all think? |
Bleyseng |
Oct 27 2004, 06:18 PM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
oops, yup I meant 5.5" Fuchs. If you are still four bolt then you could always have a set of steelies welded up to be 6 or 7 with the right offset to stay cheap. Brad said he had a line of someone who will do this. I'd go with the fuchs until you can switch to 5 bolt setup where there is more choices. Its all about choice right?
I am running 21mm Tbars and 21 sway bar and 180lb rear springs. Have some 200# to put on but no time. Koni's up front and Bilstiens in the back. 7x15 cookies with Kuhmos. Car is pretty neutral and I am not driving to the level of the set up. My son Blair drives the car faster and usually is up in the top 3 of our race group. I wish I had my car at the WCC for that course as it was wayy fun even in RichL car. I still get back to keep the car balanced and then slowly change things as you improve or your driving skills exceed the cars capablity. With a stockish car thats easy but after throwing lots of money at the car drive it instead of adding more stuff. Find out what it can and can't do like when it was stock. Like I said I really like the 7's as they work well. Just can't decide if I want to flare the car yet. Geoff |
Lo-Fi Version | Time is now: 1st June 2024 - 11:19 PM |
