| sdoolin |
Jun 6 2016, 12:24 PM
Member ![]() ![]() Group: Members Posts: 418 Joined: 1-May 14 From: LouKY Member No.: 17,299 Region Association: None |
I have searched - cannot find much on aftermarket CHT Gauges.
I am building a 2056 that will run dual Dells - would like to install a quality CHT gauge and wondering what others have used. |
| JoeD |
Jun 6 2016, 12:37 PM
Member ![]() ![]() Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States
Researched this when I was looking to put one in my car. Most folks weren't too happy with the VDO CHT and many recommended Aircraft Spruce. I bought the following and have installed all but the sensor as I am still waiting on engine; I've included part numbers and what I paid back in November:
aircraftspruce.com 10-01425 2" CHT PYROMETER GAUGE 61.75 10-00823 CHT PROBE 14MM M-1000 23.95 10-01443 15 CHT EXTENSION LEAD 51.25 |
| Mark Henry |
Apr 26 2017, 08:13 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I'm happy with my VDO gauge and sender. I'm not looking for 100% accurate numbers, but more over I'm looking for drastic changes while driving and for that I think the VDO is just fine. Plus the VDO matches the other gauges in my console (except for the wide-band o2 GAUGE) (IMG:style_emoticons/default/agree.gif) While most definitely not the best gauge it is better than nothing. My aftermarket EFI also has a head temp gauge and they seem to be in the same ballpark. But I also agree the Aircraft Spruce Micro 1000 unit is a better choice. |
sdoolin CHT Gauge Jun 6 2016, 12:24 PM
jeffdon
Researched this when I was looking to put one in ... Jun 7 2016, 09:16 AM
McMark
Researched this when I was looking to put one in ... Aug 28 2016, 06:43 AM
BeatNavy I'm running a Dakota Digital.
I think there... Jun 6 2016, 01:18 PM
76-914
I think ther... Jun 6 2016, 06:32 PM
BeatNavy
[quote name='BeatNavy' post='2355644' date='Jun 6... Jun 6 2016, 06:50 PM
era vulgaris I'm running the MGL Avionics Stratomaster Velo... Jun 6 2016, 01:25 PM
Mueller
I'm running the MGL Avionics Stratomaster Vel... Jun 6 2016, 01:28 PM
Downunderman http://www.speedhut.com/gauges/Temperature...id=f2... Jun 6 2016, 02:11 PM
ThinAir
http://www.speedhut.com/gauges/Temperature...id=f... Jun 6 2016, 10:59 PM
Mueller For the true DIY guy...
https://learn.adafruit.... Jun 6 2016, 02:41 PM
sdoolin Thanks for the info - I knew y'all would be ab... Jun 6 2016, 05:52 PM
BeatNavy
First - can I assume these CHT gauges utilize the... Jun 6 2016, 06:20 PM
Steve Pratel
Thanks for the info - I knew y'all would be a... Aug 28 2016, 01:07 PM
Porschef Like Rob, I've been running a Dakota unit for ... Jun 6 2016, 07:26 PM
Jake Raby Never, under any circumstance should the stock CHT... Jun 7 2016, 06:52 AM
sdoolin Under the spark plug it is then. I assume these ga... Jun 7 2016, 07:00 AM
Mueller Jake, any special prep to the surface where the se... Jun 7 2016, 07:16 AM
wes I have been reading this and was planning to put a... Jun 8 2016, 12:57 PM
tradisrad I'm happy with my VDO gauge and sender. I... Jun 8 2016, 01:31 PM
Mblizzard I just added the Dakota Digtial. I was wondering w... Aug 27 2016, 08:47 PM
BeatNavy
I just added the Dakota Digtial. I was wondering ... Aug 28 2016, 06:16 AM
Mblizzard
I just added the Dakota Digtial. I was wondering... Aug 28 2016, 08:22 AM
kgruen2
I just added the Dakota Digtial. I was wondering ... Apr 27 2017, 02:55 AM
eyesright I went with a VDO CHT along with an oil pressure a... Aug 27 2016, 08:57 PM
Steve Pratel I've been running the VDO gauge with the VDO s... Aug 28 2016, 12:57 PM
kgruen2
I have searched - cannot find much on aftermarket... Apr 26 2017, 02:07 AM
Elliot Cannon I have used a VDO gauge with the spark plug sender... Apr 26 2017, 10:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 01:29 PM |
