| jeffdon |
May 3 2017, 09:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
I have kinda had it with the locally available bits and abrasives. Doing a lot of drilling in hot rolled steel, and am slated to have to do tons more. There has got to be something better than the Irwin brand cobalt bits for this.
Found this site: http://www.wintersdrillbitcity.com/ It does not have a much info in the way of prices, etc. Rather old school. Anyone have any experience with these guys? Or any suggestions? I am so done buying drill sets, and would just like to buy the bits I tend to use by the dozen or more. Also, been doing some finishing on steel flat bar that needs to be glass smooth. Been having good results with a belt sander running the black gator brand belts, but like the drill bits, wonder if there might be something better. Fabricators, chime in! |
| Elliot Cannon |
May 4 2017, 10:53 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Get rid of the abrasive blade. Go to dry cut blade. The difference is amazing. Everything is easier with a drill press. I will use a drill bit in my drill press that works so much better than with my hand held drill motor.
jeffdon SOT: Drill bits, and abrasives for metal May 3 2017, 09:28 PM
cary My choice in drill bits is Norsemen/Viking.
http:... May 3 2017, 10:28 PM
jd74914 Best abrasives are from Lehigh Valley Abrasives. :... May 3 2017, 10:38 PM
PlantMan Stick with USA or European bits from a quality hig... May 3 2017, 10:41 PM
jeffdon All awesome info. Thanks, All! May 3 2017, 11:17 PM
saigon71 During my restoration, I had excellent results wit... May 4 2017, 05:43 AM
The Cabinetmaker Mirka gold. Best abrasives available in my opinion... May 4 2017, 05:59 AM
McMark Get yourself a Drill Doctor too. You can resharpe... May 4 2017, 06:08 AM
no1uno +1 to Norseman. Use their T190-AG bits. 135* spli... May 4 2017, 06:51 AM
6freak you on a press or just a drill motor,speed kills m... May 4 2017, 06:56 AM
76-914 :agree: Low speed, lubrication and knowing when th... May 4 2017, 08:08 AM
mbseto
QfT May 4 2017, 02:30 PM
Mueller If cutting metal I'd ditch the abrasive saw...... May 4 2017, 03:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:31 AM |
