> Front suspension rebuild, Partial
HalfMoon
post May 5 2017, 05:50 PM
Sooo...it's come time to refurbish my front suspension. I don't need to do tie rods or sway bar bushings and I'm not going to work on the steering rack yet, so this'll be a "partial" rebuild.
I did some searching but really couldn't find a comprehensive guide to rebuilding the 914 front suspension. Does anyone have a link to something?
I gather what I'll be doing is the torsion bar bushings, the wheel bearings and the ball joints? Are their more bushings and or bearings that I haven't included?
Thanks all!
jmitro
post May 6 2017, 06:40 AM
this has every possible item that needs attention in the front suspension.
obviously brakes and steering rack are not suspension items but you get the idea....
http://www.elephantracing.com/suspension/d...siondiagram.htm
HalfMoon   Front suspension rebuild   May 5 2017, 05:50 PM
mepstein   Turbo tie rods, front strut inserts, new brake sof...   May 5 2017, 06:40 PM
jmitro   this has every possible item that needs attention ...   May 6 2017, 06:40 AM
HalfMoon   this has every possible item that needs attention...   May 6 2017, 03:51 PM
HalfMoon   Sooooo, pretty much the (4) control arm bushings, ...   May 6 2017, 05:18 PM
michael7810   I'm happy with the rubber bushings from Elepha...   May 6 2017, 07:15 PM
HalfMoon   I'm happy with the rubber bushings from Eleph...   May 6 2017, 07:36 PM
michael7810   I'm happy with the rubber bushings from Elep...   May 7 2017, 07:02 AM
HalfMoon   [quote name='HalfMoon' post='2483347' date='May 6...   May 7 2017, 07:37 AM
GeorgeRud   Unless you're racing the car, stick with the r...   May 6 2017, 07:20 PM
BillC   I'm going to be replacing the control arm bush...   May 8 2017, 09:16 AM
mepstein   Many people have said the URO's squeak - a lot...   May 8 2017, 10:20 AM
BillC   Many people have said the URO's squeak - a lo...   May 8 2017, 05:30 PM
Mikey914   Many people have said the URO's squeak - a lo...   May 9 2017, 08:48 PM
BillC   No, we will make the better. :D Any idea when?...   May 10 2017, 01:35 PM
Eric_Shea   Many people have said the URO's squeak - a lo...   May 23 2017, 05:04 PM
raynekat   Elephant Racing rubber bushings are great and wort...   May 8 2017, 06:49 PM
HalfMoon   Figured out my wobble. PO had failed to use a lock...   May 9 2017, 01:44 PM
porschetub   Yes I can imagine the URO stuff is :stromberg: ,r...   May 9 2017, 10:29 PM
Mikey914   Tooling is underway right now. We have some testin...   May 10 2017, 06:49 PM
HalfMoon   Well replacing the ball joints didn't fix my h...   May 22 2017, 04:40 PM
mepstein   Check the wheel balance.   May 22 2017, 06:10 PM
914_teener   Yes.....I have actual experience. Looking at your...   May 23 2017, 05:42 PM
HalfMoon   Yes.....I have actual experience. Looking at you...   May 24 2017, 05:02 PM
914_teener   One other thing....check the steering shaft couple...   May 23 2017, 05:47 PM
HalfMoon   One other thing....check the steering shaft coupl...   May 24 2017, 05:02 PM
HalfMoon   Well I managed to get the stock rack out today and...   May 24 2017, 05:03 PM
Mendivil26   Hello, Did you end up figuring out what the wobble...   May 7 2019, 06:33 AM
HalfMoon   Hello, Did you end up figuring out what the wobbl...   May 7 2019, 08:18 AM
rhodyguy   Lowering your car? Bumpsteer kit. 'Shorting...   May 7 2019, 08:31 AM
Larmo63   I haven't heard of anyone dissatisfied with th...   May 7 2019, 08:59 AM
- Lo-Fi Version Time is now: 4th October 2026 - 07:14 AM
