Keep Stock oil cooler and oil filter with full flow w/ external oil cooler, Full flow case to external oil cooler |
lonewolfe |
May 6 2017, 06:54 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
Is there any reason not to keep the stock oil cooler and stock oil filter setup when running a full flow case to an external oil cooler?
Mark Henry |
May 6 2017, 07:39 PM
The reason I'd give is when you tap and plug the pump you actually enlarge the outlet hole and that hole sits in a little deeper than the stock T4 pump. You are risking a leak directly into the case where you definitely don't want a leak.
It's likely is a low risk but why take it? The other thing is the stock console has a bypass valve that is redundant, as most modern oil filters have a built in bypass valve. Personally I prefer using the full flow cover method, but if you want to keep the stock console I'd recommend using a filter adapter. You do realize to run a full flow cover on a 914 you have to modify the 3/4 side engine mount to clear the outlet. |
lonewolfe |
May 6 2017, 08:47 PM
The reason I'd give is when you tap and plug the pump you actually enlarge the outlet hole and that hole sits in a little deeper than the stock T4 pump. You are risking a leak directly into the case where you definitely don't want a leak. It's likely is a low risk but why take it? The other thing is the stock console has a bypass valve that is redundant, as most modern oil filters have a built in bypass valve. Personally I prefer using the full flow cover method, but if you want to keep the stock console I'd recommend using a filter adapter. You do realize to run a full flow cover on a 914 you have to modify the 3/4 side engine mount to clear the outlet. Yes, I realize one of the engine bar mounts needs modification. I purchased a set of modified engine mount brackets from Mark Henry. So, you're saying to eliminate the stock oil filter console with a block off plate and keep the stock oil cooler in place. Then add a remote oil filter mount inline with the oil line to external oil cooler plumbing? |
Mark Henry |
May 7 2017, 09:46 AM
Yes, I realize one of the engine bar mounts needs modification. I purchased a set of modified engine mount brackets from Mark Henry. Doh! (IMG:style_emoticons/default/slap.gif) That's right you did! One to many chairs to the head in the ring....(IMG:style_emoticons/default/biggrin.gif) Just use a remote filter mount , super easy and cheap. Use type 4 filter WIX (NAPA gold) or mahle. The best low cost hose is Parker pushloc with real pushloc fittings. No clamps! I've used parker pushloc for years, no clamps, never a failure. Note any hose can fail from improper installation, like not using grommets, sitting on an exhaust pipe, sharp edges, etc |
Lo-Fi Version | Time is now: 1st June 2024 - 06:45 PM |
