> 914 Popping and backfiring out exhaust, Need help!
SolarRT99
post May 13 2017, 07:02 PM
I'm at my wits end with this. Background on car. Originally a 74 1.8 car. Now has a 1.7 engine block with an A&A 1911cc piston kit. All new bearings, scat c45 cam with new scat lifters. Rebuilt 1.7 heads with hp springs, shims and elephant feet adjusters. Pertronix ignition with flamethrower coil. Dual Weber 40's. SS 2.0 Heat exchangers with Sebring exhaust. New cap, rotor, plugs, and wires. I have set the valves 3 times and it still has a pop out the exhaust at idle. Carbs were rebuilt last year. I think 3 and 4 aren't firing completely even though it idles fairly well. I crawled underneath with my nc temp gun and 1 and 2 are at 500+ degrees at the exhaust pipe right off the engine, 3 is right around 350 degrees and 4 is around 220. Could it be a bad carb? I tried new plugs and wires and nothing changed. Any thoughts or ideas appreciated.
Thanks
pics here
https://drive.google.com/drive/folders/0Byp...d28?usp=sharing
- Lo-Fi Version Time is now: 2nd April 2026 - 01:05 PM
