Snorkle Installation, How to info needed |
jdgreen |
May 14 2017, 12:29 PM
Newbie Group: Members Posts: 2 Joined: 9-June 14 From: N E Ohio Member No.: 17,461 Region Association: None |
Have purchased new Snorkle from 914 Rubber. Looks like many have been sold. Now time to install it. I can not find any posts with info on this subject. Will connector for relay board fit thru as is? will protective cover over wiring need cut off and replaced? Is there a covering to use if cover stripped off? Any help appreciated from those that have done this job.
JeffBowlsby |
May 15 2017, 10:04 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
1. Disconnect the rear portion of the chassis harness at the battery, oil temp sender wire, fuel pump, engine bay light, 14-pin connector at power panel, ground point under power panel, both taillights and both license plate lights. Loosen tabs at rear firewall to free up harness and pull harness through engine shelf hole to below the engine shelf.
2. Remove the plastic connector housings at the 14 pin, fuel pump and oil temp sender wire, record the wire position by color/stripe at the 14-pin connector. 3. Cut off the old snorkel grommet. Slide on the new snorkel grommet (be sure the correct end goes on first) using plenty of KY jelly as lube - nothing oil based. Clean off the KY residue after installation. Its a tight fit and patience is required to be sure, but the KY is the secret sauce. 4. Reconnect the harness to everything. |
Lo-Fi Version | Time is now: 9th June 2024 - 07:03 PM |
