Clutch cable tube in tunnel, should there be any movement ? |
porschetub |
May 16 2017, 03:44 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have some movement @ the front securing bracket ,is that normal or is it starting to break ?
Reason I ask is I have had to adjust my new clutch several times,maybe my new cable is continually stretching as I have set to correct freeplay on every occasion. Had my gearbox out to replace input shaft seal and besides minor oil contamination (cleaned up ) it was well....a new clutch. TIA |
Rand |
May 16 2017, 03:53 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
Sounds like it's more than starting. (IMG:style_emoticons/default/sad.gif)
I'd reinforce in the tunnel and at the firewall in the engine compartment, and the sooner the better. Even if it was something else, this is an upgrade we'll all need at some point. |
Lo-Fi Version | Time is now: 23rd May 2024 - 01:29 AM |
