> Speedo/Odometer questions, Gears, lube, and more
bbrock
post May 17 2017, 09:55 AM
So I completed the odometer repair following the tech article on the bird. PIA but it seemed to go well enough. But I have a few questions before I button this thing up.
  1. It was recommended that I replace the plastic drive gear while I'm in there as they are prone to failure. But I"m not sure what gear needs replacement and the most likely suspects are metal on mine. Does this not apply to me?
  2. While in there, I freshened the grease on the worm, and other gears with multi-purpose grease. Later, I read that petroleum grease breaks down the plastic gears and is responsible for the failures. Should I clean out the grease and replace with a different lubricant? If so, what?
  3. In testing, my odometer advances the mileage when the trip meter reaches 9/10 of a mile. Is there a way to align these so the odometer advances in sync with the trip meter as it rolls over a new mile? My trip meter and odometer never worked since I owned the car so I don't know what is normal and maybe I'm being too picky.
  4. This is an idiot question but is there any magic that would whiten the tenth mile wheel short of removing and painting? Dreaming the impossible!
Thanks again for all the great advice from the brain trust.
burton73
post May 17 2017, 12:31 PM
Senior member, and old dude
Hay Brock,
I guess I gave you some miss information on the drive but at least you got your speedo questions answered. My 911 Carrera 86 broke a couple of months ago when I pushed the trip reset.
Have you cleared you the plastic on the face with Novus 1 and 2 polish for plastic or am I wrong one more time and you have glass fronts?
Your doing great on your restoring of you baby.
Bob B
- Lo-Fi Version Time is now: 4th October 2026 - 07:22 PM
