Redraptor |
Newbie ![]() Group: Members Posts: 36 Joined: 18-October 16 From: Louisville, KY Member No.: 20,501 Region Association: MidAtlantic Region ![]() |
I'm trying to separate my tranny from the engine, they are both out of the car, the tranny just wiggles around.. I had seen a thread on this earlier in the week except I cant seem to locate it now.
The starter is removed and so are the other three bolts. Am I missing something or just a solid application of elbow grease? |
BillC |
Senior Member ![]() ![]() ![]() Group: Members Posts: 678 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region ![]() ![]() |
Has the car been sitting for a while? It's possible the clutch disk might be stuck on the input shaft.
If it is stuck, here's an idea that might help:
To make it easier to pull the clutch fork, you can use two screwdrivers, a long one and a shorter one. Put the shorter one in the slot where the posts of the cable block go, and then use the long screwdriver to wedge in the "hole" in the end of the clutch fork and the short screwdriver. |
Redraptor |
Has the car been sitting for a while? It's possible the clutch disk might be stuck on the input shaft. If it is stuck, here's an idea that might help:
To make it easier to pull the clutch fork, you can use two screwdrivers, a long one and a shorter one. Put the shorter one in the slot where the posts of the cable block go, and then use the long screwdriver to wedge in the "hole" in the end of the clutch fork and the short screwdriver. She has been sitting for 30 years. Can you quantify the amount of force needed? Are we talking a difficult bolt (i've had alot of thos recently) or one man doing the work of two after said man breaks the dolly the engine is resting on and now has to move it to a new dolly? (Did that too) Which direction do I pull? |
Lo-Fi Version | Time is now: 16th July 2025 - 04:18 PM |
