First post , First 914-8, Saying hello |
Sean_S |
Oct 21 2004, 01:55 AM
Mine goes to "11" Group: Members Posts: 48 Joined: 21-October 04 From: Coos Bay, OR Member No.: 2,979 |
Hello All !
My name is Sean and I've been lurking here for a few hours and figured I'd best register since I just purchased my first 914 V8 conversion. I live in Coos Bay Oregon as a Los Angeles escapee. In my former life I was a machinery dealer and thankfully this has provided me with a full machine shop (kept the cream for myself). Hopefully this will help with that trials of owning this conversion. I also have a custom Lotus Esprit S1 and a Toyota FJ-40. I've owned and converted several FJ's to V8's so I'm comfortable with tweaking and re-tweaking. I may at some point convert the Lotus, but the engine is fresh so it will wait. In any case, here is a photo of the 914 conversion. I haven't gotten into it yet, but basically it's a 5.0 EFI conversion...let me know what you think? Also, I am interested in hearing from the V8 guys (and gals) about the performance of their cars and any 91(8) advice that a newbie must know. All the Best Sean (IMG:http://img.photobucket.com/albums/v500/twomarbles/914/DSC00714.jpg) |
Sean_S |
Oct 28 2004, 10:53 PM
Oh by the way... you guys will get a kick out of this...
The (currently out of car) cooling "routing" is via hard steel pipes welded to shape and fixtured for bolting to the bottom of the car. Imagine going to the hardware store and getting gavanized plumbing pipe...welding it for the bends you want, making brackets so it bolts flush to the undercarriage, and then going an powercoating the whole thing? Weird. The water pump is an external deal out some Olds or something which has about a 3/4" ID. Truth is, I cannot see why you wouldn't run the same 3/4" through the original heater ducts to the front. Hydrodynamics would lean that there is very little to gain (an possible loss) in running a larger ID than the water pump orfice has. My 210hp Lotus (which is a hot engine) uses only about 3/4" ID hose from the front to back in it works fine (as it should). I'll have pic's of this coming too, but I guess I'll be changing that or learning why I should leave the PO's design. Sean |
Lo-Fi Version | Time is now: 9th June 2024 - 04:07 PM |
