| Robnxious |
May 20 2017, 11:43 AM
RobnxiousOne ![]() ![]() Group: Members Posts: 184 Joined: 26-October 06 From: Sacramento Member No.: 7,097 Region Association: Northern California |
When I had my car wrapped the kids who did it did something to the rear trunk release and I am going in there today. So actually I can hear the solenoid triggering but it's not open, and I will fix that when I am in there. I have read the posts on here and have a pretty good idea how to do it, and have the proper tools. Just want to verify with anyone who has gotten into the rear trunk through the engine compartment.
1) I am assuming you go through the holes that are covered by the plastic caps (guessing strut holes), but how does one who is, shall we say "not as svelte" get in there to get the ratchet back there 2) I have also read about drilling a hole beneath the solenoid and triggering the release that way (Which I am thinking about doing, since I need to put the idiot release in since the DAPO didn't but a failsafe on it). Anyone got any suggestions since I want to not only get into it today, but also put my new chrome bumpers and bumper tops on this weekend, and I know I need to get into the trunk to do the rear bumper Thanks in advance |
| oakdalecurtis |
May 20 2017, 01:25 PM
Oakdalecurtis ![]() ![]() ![]() Group: Members Posts: 1,401 Joined: 5-June 15 From: Oakdale, Ca Member No.: 18,802 Region Association: Central California
I have a rear reflector lens, so I can not use the original push button. I STRONGLY suggest the you add a small cable attached to the release arm in the trunk and run it through a small hole in the bottom of the trunk. Have the cable end up where it cannot be seen from the back of the car, and put a small pull tip on it, see pictures. I guarantee that at some point the solenoid will stick or the battery is too low and it will not release the trunk lid when you need it most. The cable is a backup that you can always use to open the trunk.
Robnxious Rear Trunk opening May 20 2017, 11:43 AM
Bartlett 914
When I had my car wrapped the kids who did it did... May 20 2017, 12:07 PM
Robnxious
Have someone hold the button while you press down... May 20 2017, 12:54 PM
Garold Shaffer
When I had my car wrapped the kids who did it did... May 20 2017, 01:20 PM
Robnxious
In response to item 1)
however many extensions ... May 20 2017, 01:30 PM
Robnxious
I have a rear reflector lens, so I can not use th... May 20 2017, 01:32 PM
larryM since you have the rear reflector - it is relative... May 20 2017, 11:18 PM
Robnxious
since you have the rear reflector - it is relativ... May 21 2017, 11:01 AM
rjames No need to drill any holes. Get a long enough ... May 21 2017, 12:19 AM
Bartlett 914 I always wanted to make a hinged license plate hol... May 21 2017, 08:35 AM
Robnxious Larry, that worked like a charm!. Took like 30... May 21 2017, 11:46 AM
larryM good news!
Larry, that worked like a charm... May 22 2017, 10:04 AM
burton73 If you go this route?, place masking tape over the... May 22 2017, 11:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 12:31 PM |
