Stripped cone screw....need remedy.., Allen portion stripped...muscle f'd it.... |
second wind |
May 22 2017, 09:50 AM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Well.....life long ailment of fixing something that is working fine already.....I wanted to make sure my shift rod was rrreeellllyyyy tight.....well, it is now! Can't get cone screw back out. Any ideas? Thanks.
gg |
Amphicar770 |
May 22 2017, 12:09 PM
Senior Member Group: Members Posts: 1,195 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Dave's approach is the one most likely to work. If you do not have a welder handy, put a dab of JB-Weld in the cone screw where Allen wrench goes. Find an allen wrench you are willing to part with, put it in there and let the JB-Weld dry.
Alternatively, Beat a Torx bit attached to an extension into the rounded out screw. You can also try these, I have no experience with them. https://www.amazon.com/IRWIN-HANSON-Multi-S...7/dp/B0002SRG66 |
jeffdon |
May 22 2017, 01:39 PM
Senior Member Group: Members Posts: 1,094 Joined: 24-October 06 From: oakland, ca Member No.: 7,087 Region Association: None |
Dave's approach is the one most likely to work. If you do not have a welder handy, put a dab of JB-Weld in the cone screw where Allen wrench goes. Find an allen wrench you are willing to part with, put it in there and let the JB-Weld dry. Alternatively, Beat a Torx bit attached to an extension into the rounded out screw. You can also try these, I have no experience with them. https://www.amazon.com/IRWIN-HANSON-Multi-S...7/dp/B0002SRG66 Torx bit hs worked for me. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 04:01 AM |
