New ACC. Cable / Clutch Cable Conflicting, Sometimes getting gas / higher revs when depressing clutch... |
MikeInMunich |
May 23 2017, 06:24 AM
Member Group: Members Posts: 392 Joined: 19-November 13 From: Munich, Germany Member No.: 16,674 Region Association: None |
That says it all. We weren't successful installing the new accelerator cable without getting it somehow twisted / conflicting with the clutch cable.
Looking for more tips beyond those already discussed here in other threads on this issue on how to avoid this. We should pull it back out to the firewall and try again, I presume, but we are 100% blind, just pushing it into the tube and looking for it to come out near the pedal. Is it at all possible or not to be SURE that there is no conflict, and if so, then please, by all means, describe how to do it. Thanks very much! With best regards, M.i.M. (IMG:style_emoticons/default/beerchug.gif) |
saigon71 |
May 23 2017, 07:27 AM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I just went through this too over the winter.
The borescope is a great idea if you have one. If not, use an inspection mirror so you can see if anything is routed wrong when making the final connection. |
Lo-Fi Version | Time is now: 6th June 2024 - 07:19 AM |
