Expert help from you body guys PLEASE, Door Gaps |
xperu |
May 26 2017, 08:27 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
I know door gaps is an old story, but I am at a crossroad in regard to what I am going to do with my beloved 914. I had inner stiffing kit installed and the guy did not install temp bracing to prevent heat shrinkage thus my door gaps puled in, so now I have very little gap between door and body. This problem is more prevalent on the passenger side then the drivers.
Later I had the Restoration Design long clamshells installed by another shop to stiffen the car. We also would attempt to possibly move the door gaps a little in the process. This did not work, but the long stiffeners really improved the stiffness of the car and it handles very well. My real question here is can anything be done to the car at this point to widen the door gaps? Other than the gap issue, the car is pretty much a new, all the bushing, suspension, engine rebuild etc. are done, the interior is in very good condition. I have had this 914 for 10+ years “my 4th one” it’s excellent for autocross, but the value of the car may be in jeopardy if I can’t resolve the gap problem. Any suggestion for you body guys would be greatly appreciated. Thanks Mike |
mskala |
May 26 2017, 11:50 AM
R Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None |
I know next-to-nothing, but would it work if you had at least the longs to bare metal,
repeat heating part of the long to a low temp like 300F, brace solidly only as it cooled? Basically reverse of the welding shrinkage problem. |
mb911 |
May 26 2017, 12:27 PM
914 Guru Group: Members Posts: 6,871 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
I know next-to-nothing, but would it work if you had at least the longs to bare metal, repeat heating part of the long to a low temp like 300F, brace solidly only as it cooled? Basically reverse of the welding shrinkage problem. It would need to get a but hotter so the metal was in a plastic state. That is how we stress relieved new aircraft fuselage when pulling them out of a fixture. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:17 AM |
